| blamchez |
 blamchez Scooby Slapper
| Ciar?n |
 Ciar?n World Chat Champion
| Imonster |
 Imonster World Chat Champion
 Posted: 11:39 - 20 Jul 2007 Post subject: |
I'm not expert but certainly for town work I've known a few couriers who opted for getting two or three examples of an older, small capacity, cheap and easy to repair bike rather than one bigger, newer one.
They don't make superdreams any more but something like that. You used to be able to get three vaguely tatty but well running superdreams for the same price as a moderately tidy CB500. This allows you to be riding one, fixing one and still have a spare. Also means you can rob parts and replace them at your leisure if you need to. Keeps you on the road earning money rather than in the garage waiting. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| map |
 map Mr Calendar
 Posted: 11:45 - 20 Jul 2007 Post subject: |
GT550
Cheap to buy. Cheap to insure. Shaft drive so little maintenance. Parts available via breakers. Less to tax as below 600cc. Can fit panniers & top box easily (if not already on). Can also fit fairing if required for a little weather protection. Engine crash bars available too. Ok for in town and can do a little distance work too. Sounds like a winner.
Downside of the GT550 are the carb diaphragms as they can split. Expensive to replace although refurb ones available from a place in Manchester near Victoria station (google or search here). Failing that they can be bodged to keep going. Also balancing 4 carbs is a knack but once done generally keeps ok for a while (unless other problems).
Failing that the other shaft drive that usually gets a mention is the NTV650 (and variants there of). It's what the Deauville evolved into but don't let that put you off.
IMO things like the Honda CX are getting a tad long in the tooth. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| neatbik |
 neatbik World Chat Champion
 Posted: 13:06 - 20 Jul 2007 Post subject: |
Honda cb1 maybe? cheap to run and buy, very very well built and reliable, comfy and good fun too  |
| Dibble |
 Dibble Scooby Slapper
 Posted: 13:36 - 20 Jul 2007 Post subject: |
| Quote: | I'm not expert but certainly for town work I've known a few couriers who opted for getting two or three examples of an older, small capacity, cheap and easy to repair bike rather than one bigger, newer one.
Often with the same number plate on all 3 bikes
To start off with you'll be too slow in town to make a lot of money and you may find your controller sending you off in unpopular directions (Brighton,birmingham etc.) with one job on board.(I'm presuming you are going to work in London) So you want an all rounder.
To run through a few bikes I worked on:
GT550-old rough,carb rubbers as mentioned,primary drive chain wear(not damaging but sounds rough).Frames snap-it happened to me(take off the tank and look for welding).don't trust the fuel guage. wireing loom wears through on full lock.Every bike within the M25 has been despatched into the ground.
CX500-old rough ,bad fuel economy~85-100 miles on a tank people remove the air filter to improve it,superb massive headlight.increadibly reliable.Single front disc is american import.Most comfortable seat in the world. Increadibly heavy when you drop them.Strange floaty wobble when cornering can be caused by people fitting a wide rear tyre. You can easily fit 1xA4box in the topbox,1on the seat and at a push put one on the tank. I loved mine but they are old
Bros400, tiny light lovely in town,easy to get through gaps,Miniscule fuel tank causes problems on motorways,can't fit much on board.Very quiet means you may run over the odd tourist. If you take a lardy pillion the helmet holder can cut a groove in the rear tyre, fuel pumps fail.
CB1-no power till 9000rpm then lots till 13,500 means hard work a bit too twitchy for friday afternoon after working 50hours in the wet. Only fun if your in the mood.Saw nice one for£750 last week
XT600/DR600 both similar ,good in town limited carrying capacity. Ride one in winter and spend your days chasing minimums rather than freezing on the motorway. Trailies crash well.
CB500,green ones seem to be more reliable but there all near perfect.
CG125.no acceleration so don't brake maybe thats why the brakes are so bad. If I had a large package in my bag I could only do 50mph on the A12. Cost almost nothing to run.
You could also look at Bandits,Diversions,NTV/Revere/deauville.KLE500.GS500.Africa twin.TDM.VFR750
Whatever you use it's going to get knackered you may do 4000miles a month against the national average of ~3000 a year.
I've known people despatch most bikes:Harleys ,BSAs, EXUPs one guy used to turn up on a RC30 on quiet sunny days but I woulden't advise anything too nice to start off with......Have fun I did 5 years on plot and loved it
| Finglonga |
 Finglonga World Chat Champion
| Trixie |
 Trixie World Chat Champion
| mr.z |
 mr.z World Chat Champion
| Kal |
 Kal World Chat Champion
| Dibble |
| Kal |
| mr.z |
 Posted: 15:02 - 20 Jul 2007 Post subject: |
Custom has quite a bit smaller tank (other tanks do fit but its getting hold of one thats not stuffed) and the smaller rear wheel, although same probably applys with the trike with the gearing and all not to mention carrying that extra load...
A mate had a 650 trike which he ragged the sheeart out of and still got 35mpg if i remember correctly.
Interestingly on the 650 if I'm really spanging it i still get 185 or so, not been on a motorway on it yet but supposedly the economy is even better..
tbh I'd like another 500 twinshock, they are wobbly handling but treat it like what it is and usually it wont disappoint.. but they are getting fewer and the mileages are climbing, when i can afford it i'll probably move onto something modern but straightforward with parts a plenty, but when you've had a shaft drive bike its difficult to go back to pissing about with chains :/ ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Kal |
| Spoon261 |
 Spoon261 Trackday Trickster
 Posted: 15:21 - 20 Jul 2007 Post subject: |
I nearly bought a new Honda CBF250 since my local dealer tried to get rid of it for £2700.
But then I searched the internet for user reviews.
Only one person has reviewed it and posted on several websites.
He reported the chain and sprocket had to be constantly replaced. Not sure but it could be in his 10,000 miles the chain was replaced twice and the sprocket once?
He also had engine trouble, actually loads of engine trouble, it was a real lemon.
And Honda uk refused to help him.
The bike made in brazil and seems to have far worse build and reliability than the bullet proof Honda CG125 they make their.
If anyone has experience owning a Honda CBF250, please write a review of your experiences!
The Honda CB500 was much better with a fairing on, the petrol consumption went for 50 to 60mpg to 60 to 70mpg. The top speed also increased by 10mph?
I have ended up downsizing to a Honda CG125 new model (front disc brake), the brakes are more than enough when they have run in. Changing from the original Pirelli City Demons to the Michelin Pilot Sporty (based on the Pilot Sport) tyres transformed the cornering (I could double the speed in tight corners), improved rolling resistance, comfort, feel of the road, braking and can change direction while in a tight bend and severe braking and yet the tyres are wearing far slower than the Pirelli!
Saying all that the CG125, is very slow to accelerate and is only 50mph in server head wind and up steep hills. But I can leave 500cc bikes and above for dead when on very tight corners and on roundabouts.
What killed the Honda CB500 or CBF500 for me was the 16,000 mile valve clearance shims. I would need the confidence to do it myself since the garages charge several hundreds of pounds! |
| mr.z |
 Posted: 15:24 - 20 Jul 2007 Post subject: |
There is indeed, they overbore it and tweak some other stuff, not sure of the cost but afaik it was fairly reasonable..
There is a guy in oz who drag races turbos actually, but for some reason he tend to use 500engines and have them overbored, dunno why but i think he gets through a few
Back on topic, a bandit might be worth considering? also they still make the cb250, guess it depends what sort of couriering it is..
If you can afford a good one i'd say the transalp would be bloody fantastic for courier work  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| FreshAL |
 FreshAL Sir Crashalot
 Posted: 15:50 - 20 Jul 2007 Post subject: |
 Posted: 17:02 - 20 Jul 2007 Post subject: |
I've spoken to a few people who have dispatched on MZ 2-stroke singles in town too. You could probably buy four or five runners for the price of a CB500. They do break down on occasion but not in any major way, the only major pain is the gear lever return spring goes (bungee to footpeg until you can be arsed fixing it) and they occasionally warp clutch baskets.
Piece of piss to work on if they do break, otherwise a bog-basic, piston ported 2-smoke. Air cooled, very frugal on fuel and air cooled so they won't overheat in the summer. If a top-end rebuild takes over an hour (including making a new base gasket), you're doing it wrong.
Surprisingly torquey at low revs (the engine is based on a 1960's trials motor) so they'll scoot through traffic no bother.
Or I suppose for the ultimate town bike, the C90, or the newer innova 125. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 17:10 - 20 Jul 2007 Post subject: |
I see quite a few Hornet 6's on my travels in London, and more and more CBF600's(de-tuned(80ish bhp) semi faired Hornet) are appearing too. ____________________ My Flickr |
| craigs23 |
 craigs23 Mr Muscle
| chris-red |
| Itchy |
 Itchy Super Spammer
 Posted: 20:58 - 20 Jul 2007 Post subject: |
read Sickpup's courier bike guide here
https://www.bikechatforums.com/viewtopic.php?p=815836#815836
from a man in the know!
I personally recomend an NTV600 or a GT750 (if you are in a hurry) or a CX . ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| hmmmnz |
 hmmmnz Super Spammer
| Imonster |
 Posted: 19:22 - 21 Jul 2007 Post subject: |
It would be a cold day in hell before I used this company again...avoid them like the plague  ____________________ Those who make peaceful revolution impossible will make violent revolution inevitable. |
The last post was made 19 years, 82 days ago. Instead of replying here, would creating a new thread be more useful? |
