Running without a silencer...
Korn
Admin
PostPosted: 11:01 - 24 Oct 2003    Post subject: Running without a silencer... Reply with quote
Anybody know what the practical implications are of ditching the can and going without? Don't worry this isn't for my storm - it's for the gokart.
Thinking of just chopping the link pipe down at the point marked in the picture - any ideas what effect that would have on power/running?
3516 Miles, 11 Countries
Demonic69
The Pink Rhino
PostPosted: 11:05 - 24 Oct 2003    Post subject: Reply with quote
I think the engine would need setting up to run without a can.
I also think having the can at a right'angle would be best Very Happy Make the pipe either straighter or more towards the right then have a 90degree bend in it. Sorted Very Happy
Back on a Blade. Just feels so right.
PostPosted: 11:06 - 24 Oct 2003    Post subject: Reply with quote
AFAIK it would allow more air through the engine faster therefore making it run very lean.
Lean=hot.
You clould blow the engine if you have no silencer at all. If you rejet the carbs with bigger jets you could make it run fine with no can afaik. It would just be extremely LOUD!
Drag bikes run with virtually no exhaust at all and they run okay.
Back pressure could also be a problem, but methinks you're not looking for midrange poke a la exup valve.
How does the engine run with no can?
Try rejetting for no can and see what effect it has. If it works, you can cut the pipe back and it will still run the same.
If I were you though I'd attach a couple of wheels onto the exhaust there to stop wheelies! Very Happy
Hex
Party Boy
PostPosted: 11:07 - 24 Oct 2003    Post subject: Reply with quote
Running with out a can will mean it will run leaner but apart from that I don't really see any problems.
Its not like it need an expansion chamber or you have the exhaust tuned by length (now that is a real black art to me Confused ).
So an adjustment of the mixture (possibly the jets) should see it running just fine can-less, in my opinion mate. Very Happy
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
PostPosted: 11:08 - 24 Oct 2003    Post subject: Reply with quote
Incidentally,
are you running a diff on the rear axle, or is it mainly for straightlining?
It won't corner very well if not. Confused
Hex, Expansion chambers only work on 2-strokes mate. Wink
andrew
Mister Road Rage
PostPosted: 11:11 - 24 Oct 2003    Post subject: Reply with quote
Which is exactly his point Rolling Eyes
Hex
Party Boy
PostPosted: 11:12 - 24 Oct 2003    Post subject: Reply with quote
Yeah I know but it I can't be bothered to explain what I meant by tuning for exhaust length but if I'd of wrote back pressure like you it would of made more sense Razz
Kickstart@Work
PostPosted: 11:25 - 24 Oct 2003    Post subject: Reply with quote
Almost certain that the ZXR pipe will be a tuned length. Likely that by shortening the exhaust like that you will move the rpm that the pipe works best at up the rev range, quite probably with the pipe working best somewhere after the rev limiter. Also this might well move the mid range flat spot to the point where you would otherwise have peak power.
Exhausts are very complicated. Very crudely the shorter the exhaust the higher the rpm it works at.
Atheism is a not for prophet organisation
paulit
PostPosted: 11:35 - 24 Oct 2003    Post subject: Reply with quote
Exhaust tuning
All exhausts have to be tuned regardless if they are 2 or 4 stroke. and all need some kind of backpressure
hows it done, by increasing or decreasing to length of the pipe that leads into can. the wrong length can make the engine run lean or rich.
simple test.
I have a scorpion can on my r6 where the can will allow the pipe to slide in or out of the can. run the bike at 5000 rpm and slide the can further on the bike, the engine speed will increase as it gets leaner, pull the can the other way and the engine will slow down considerably as it gets richer. somewhere inbetween is the right setting. Its called a tuned pipe and thats how the manufaturers do slip ons where no re jetting is needed.
Shorten or lenghen the pipe will require rejet.
As for running with no pipe its very possible by using a reducer on the end of the pipe to create some back pressure. getting the right length is a bit more tricky and is a trial and error excercise.
computer nerds do it in Windows
Evilbob
PostPosted: 12:38 - 24 Oct 2003    Post subject: pipe Reply with quote
well i just got my race silencer pipe put back on with a dodgy made up pipe and its longer Confused and does seem allot better mid range and at the bottom and lost a bit just before top????!?!?!
but only cost £20 recon i should try and make it the same length as the original??
my karma is dieing not fair who cares about spelling? i get the point across, most of the time Smile
Kickstart@Work
PostPosted: 13:56 - 24 Oct 2003    Post subject: Reply with quote
On a 2 stroke the expansion chamber design is the important bit.
P_J
PostPosted: 12:49 - 26 Oct 2003    Post subject: Reply with quote
How about fixing it so that you can quickly/easily, fit/remove when you like?
Sure it wouldnt be too hard to bolt it on when needed.
Suppose it could be a pain in the arse if you do have to re-tune the engine to compensate for no end can/pipe in the first place though.
PJ
Dreams will get you nowhere, a good kick up the arse will take you a long way.
Only1PJ.co.uk
TiN
Pocket Tin
PostPosted: 14:49 - 29 Oct 2003    Post subject: Reply with quote
Here's some inspiration for ya:
https://www.zorstec.com/gallery_trikes/38big.jpg
TiN
dotgems.net
Racer X
PostPosted: 19:44 - 30 Oct 2003    Post subject: Reply with quote
Frikken cool!!!!!
< Live To Ride & Ride To Live >
Beezkneez
PostPosted: 20:37 - 30 Oct 2003    Post subject: Reply with quote
afaik running without a can on a 4 stroke that isn't jetted will burn the valves out or something like that.
Bazza
got a yamaha....pop over to the www.yamahaclub.com
stevo as b4
PostPosted: 21:58 - 30 Oct 2003    Post subject: Reply with quote
Lots of stunt bikes/bandit's have those like really short 4-6" cans fitted, and i would expect that there would be a slight change in carburation with a shorter pipe, but like keith and others said, on a four stroke its the length of the headers, going into the collector for a 4-1 or 4-2-1 system that really counts, and a sports bike motor might not barely run it this length is altered, as its a designed length to suit the engines characteristics. After that point you can probably set it up fairly easily to run any length of silencer/tailpipe, so long as you re-jet the carbs as required.
NSR125-Kid-UK
Attention Whore
PostPosted: 04:46 - 02 Nov 2003    Post subject: Reply with quote
I was going to say something about back pressure except it seems to have been said. All i can suggest is that you/zim get some earplugs!
https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman
The last post was made 22 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 102.24 Kb
