cog size for nsr
nsr125rossie
PostPosted: 12:37 - 28 Jul 2007    Post subject: cog size for nsr Reply with quote
hello can any one tell me do you go up a tooth or down a tooth on the front cog i have just tacking the re-stricters out the exhaust i have a 2000 nsr 125 it is now fast off the mark but still only does 75mph
ncrn
PostPosted: 12:55 - 28 Jul 2007    Post subject: Reply with quote
Did you take the plate out thats between the carb and the engine?
nsr125rossie
PostPosted: 15:27 - 28 Jul 2007    Post subject: Reply with quote
yes it was allready out
ncrn
PostPosted: 15:39 - 28 Jul 2007    Post subject: Reply with quote
Certain of that? I could go faster than that on my nsr with both restrictors in.
But all the same if you want to go faster you want to go up one tooth.
nsr125rossie
PostPosted: 15:41 - 28 Jul 2007    Post subject: Reply with quote
the cog that is on at the mo is a 13 tooth i think as standed are 14 is this right
professor151
PostPosted: 16:10 - 28 Jul 2007    Post subject: Reply with quote
Is it running out of revs in top gear? I mean are you revving it into the red?
If you go up one tooth on the front sprocket (up to 14 tooth from 13) you will, theoretically, have a new top speed of 80mph. Not much difference.
Thats obviously dependant on the condition of your engine, wheel bearings, your chain, brakes (they might be dragging) etc. Any of the cycle parts can slow you down if they're not in good condition.
As ncrn said, his NSR could do more than 75 while still restricted, so my guess is that you're barking up the wrong tree.
In fact with highly reduced gear ratios, for the short circuit track, my TZR reaches about 75 with the tacho needle just touching the red.
Double check that you have removed both restrictors, make sure everything is working nice and smoothly.
If you lift the bike off the grond the wheels should rotate freely if you spin them. It seems obvious I know, but its something you need to check every now and then.
Have you compared your bike to a friend's one maybe? Testing the acceleration against a similar model should reveal how nicely the engine is working.
nsr125rossie
PostPosted: 16:22 - 28 Jul 2007    Post subject: Reply with quote
i will have a look at everything u have said thanks
professor151
PostPosted: 16:36 - 28 Jul 2007    Post subject: Reply with quote
Good luck, keep it on two!
st3v3
PostPosted: 18:43 - 28 Jul 2007    Post subject: Reply with quote
try www.nsr125.com for info if you haven't already, or wait for alains to come along and spread that NSR wisdom
nsr125rossie
PostPosted: 18:46 - 28 Jul 2007    Post subject: Reply with quote
been there but thanks anyway
ncrn
PostPosted: 18:29 - 29 Jul 2007    Post subject: Reply with quote
I'd really want to check the carb plate is deffinetly not there. Because that really restricts your fuel intake.
When you are riding it are you riding it to the red line before changing gear?
nsr125rossie
PostPosted: 22:22 - 29 Jul 2007    Post subject: Reply with quote
yes its out it is faster off the mark now but only gets to 75 mph
The last post was made 19 years, 93 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 72.74 Kb
