NSR125RR Play in the gear shifter
Cwizard
PostPosted: 10:14 - 31 Jul 2007    Post subject: NSR125RR Play in the gear shifter Reply with quote
I have been going over the bike this weekend and noticed that the gear shifter has a reasonable amount of play side to side. if I sit on the bike and move it with my foot, its got between 5-10mm of play, wondered if anyone else had this problem and what they did about it, or if anyone else has a suggestion.
Honda NSR 125 R1 (51)
Back and better than ever!!
djrichieb
PostPosted: 10:27 - 31 Jul 2007    Post subject: Reply with quote
It shouldnt really have much side to side play. Mine was like this when i bought it. You should tighten it up a bit.
Rides: Honda CB400 SF (ART can) - Citroen Saxo 1.1i SX
Cwizard
PostPosted: 10:30 - 31 Jul 2007    Post subject: Reply with quote
didnt think so, where did you tighten it up?
djrichieb
PostPosted: 10:53 - 31 Jul 2007    Post subject: Reply with quote
i didnt actually do it myself. A freind did it for me but it was easy. Was just one bolt holding the gear shifter to the little bit that its attached to. I'll have to have a look when i get home.
st3v3
PostPosted: 18:04 - 31 Jul 2007    Post subject: Reply with quote
You need to tighten up No. 11 Thumbs Up (once you have it at your comfort angle.)
https://www.nsr125.com/schem35.jpg
Cwizard
PostPosted: 14:25 - 03 Aug 2007    Post subject: Reply with quote
tightened that screw as far as possible, rattles around still, but also the rod moves in and out slightly, is this normal? i bloody hope so, got few problems elsewhere, dont need this now Crying or Very sad
alains
PostPosted: 16:04 - 03 Aug 2007    Post subject: Reply with quote
take off piece 1 , open it for 8-10mm , with a flat file grind a bit on the 2 flat parts (1mm on each side) then refit and it will tighten much stronger
Cwizard
PostPosted: 16:10 - 03 Aug 2007    Post subject: Reply with quote
cheers alains, that was the idea for l8r, but the rod moving, thats the more worrying thing for me. any ideas?
alains
PostPosted: 16:21 - 03 Aug 2007    Post subject: Reply with quote
may be take cover off and insert a washer (may be last time the cover was off the washer has been forgotten)
Cwizard
PostPosted: 16:27 - 03 Aug 2007    Post subject: Reply with quote
this might sound quite novice Embarassed , but where on earth does it go, i have the workshop manual from honda, but thats a complete waste of time, tells me nothing. have you got any pictures showing where this washer should go?
alains
PostPosted: 16:49 - 03 Aug 2007    Post subject: Reply with quote
i had a look on mine and i think you cannot do anything but a play of 2-3 mm is normal
Cwizard
PostPosted: 16:54 - 03 Aug 2007    Post subject: Reply with quote
cheers m8, i'll have a look in a bit
The last post was made 19 years, 86 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.5 - MySQL Queries: 13 - Page Size: 72.26 Kb
