newbie question
Ben.
PostPosted: 10:44 - 04 Aug 2007    Post subject: newbie question Reply with quote
this is a big newbie question Embarassed but if i buy handlebar grip's and new brake/ clutch levers are they easy to fit? and how do you do it? will the handlebar grips jus pull off? Confused Embarassed
Thanks, HL
follow my racing season
Race bike - R6
Road bike - sv650
Rit
PostPosted: 11:06 - 04 Aug 2007    Post subject: Reply with quote
Cables (if any) will need to be slackened right off so you can get the nipple out the little hole then old one off, new one on the cables back in and readjust. Fluid systems should be even easier.
If you have bought new grips just cut the old ones off if you are struggling. I use hair spray down the new grips and slide em' on, hairspray dries and the grips are fixed fine Thumbs Up
hehe I said nipple Embarassed
You watching this rubbish?
Naaaa, switch over, Neighbours is on in a minute!
www.ritzbitz.co.uk
Ben.
PostPosted: 11:45 - 04 Aug 2007    Post subject: Reply with quote
thanks for the quick reply Thumbs Up is there any risk of me draining all my break fluid? Neutral
Race bike - R6
Road bike - sv650
Rit
PostPosted: 18:27 - 04 Aug 2007    Post subject: Reply with quote
None, all the lever does is push a piston. Also the piston is held in by a clip so it wont pop out when you take off the lever. You should be able to change levers with all other parts intact.
www.ritzbitz.co.uk
Jamie S
PostPosted: 00:11 - 05 Aug 2007    Post subject: Reply with quote
Make sure you don't lose the spring and rod out of the brake/clutch.
You sure you have a hydraulic clutch btw ? What bike is it ?
virus
PostPosted: 00:22 - 05 Aug 2007    Post subject: Reply with quote
changing grips,
Wd40 to get them off, hairspray to put new ones on
HTH
John
own: 81 xs1100g...
The last post was made 19 years, 65 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 53.01 Kb
