Best way to set up a chain
binge
Emo Kiddy
PostPosted: 15:10 - 05 Aug 2007    Post subject: Best way to set up a chain Reply with quote
I bought a pair of tyres the other day, and fitted them at work yesterday. Getting the front wheel on and off was simple enough. Even getting the rear on and off was very easy. But fitting the rear back up and adjusting the chain was only easy because I marked the position first with a marker pen. I'm still not convinced its 100% true because my chain has a "Tighter" spot, and a "Slacker" spot. Its by no means too tight when its goes tight, but its tighter than the rest of the chain.
So what is the best way to set a chain up from scratch, Surely you don't have to sit and count out turns on the chain tensioners?
<|ben|>
alone
PostPosted: 15:24 - 05 Aug 2007    Post subject: Reply with quote
Why do you need to adjust the chain tensioners? Surely just knock the spindle out and push the wheel forward, then the chain will just fall off? No?
It's how I've always done it anyway. and Mark at Ride In does it that way too.
Bikes; '06 Triumph Sprint ST 1050 (for sale) - '95 BMW R1100GS
rzren
PostPosted: 15:49 - 05 Aug 2007    Post subject: Reply with quote
Most manuals I've encountered specify that you set it up from the tight spot but there's a hair of a chance that yours could be different.
carvell
Scuttler
PostPosted: 16:31 - 05 Aug 2007    Post subject: Reply with quote
Set it up for the tight spot.
You shouldn't have to do any counting of turns, there should be marks on the swinging arm.
Yamaha TDM 850
Jamie S
PostPosted: 18:44 - 05 Aug 2007    Post subject: Reply with quote
All bikes are different don't forget.
My TLR has circular cam's and there is NO way of leaving them in the same position , were as my XS250 has bolts with loops and a thing that hooks over the frame thats set even if you take it off the bike.
PostPosted: 18:52 - 05 Aug 2007    Post subject: Reply with quote
You can also set it up from the marks on the swingarm. Although some bikes are more accurate than other. You can get a laser thingey to make sure it's exactly in line.
alone
PostPosted: 18:58 - 05 Aug 2007    Post subject: Reply with quote
I totally misunderstood, how cool do I look?
As stated above, you can get laser alignment tools, there's also a way of doing it with some pieces of wood, but I don't remember how.
Do I get some award for most useless posts?
Jamie S
PostPosted: 19:02 - 05 Aug 2007    Post subject: Reply with quote
You can indeed https://www.bikebandit.com/product/1933?WT.mc_id=5255
But for the money unless you are using it every day it seems really dear.
PostPosted: 19:04 - 05 Aug 2007    Post subject: Reply with quote
Demon tweeks do one for £50. Seems ok to me. I would get it if I had 50 quid spare. It extends the life of your chain a wee bit.
Finglonga
PostPosted: 20:34 - 05 Aug 2007    Post subject: Reply with quote
£50 for something a plank of wood can do . . . . No thanks. Thumbs Down
Andy Sez....
F.Y.Y.F.F.
The last post was made 19 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 63.65 Kb
