Neutral Light
djrichieb
PostPosted: 17:37 - 05 Aug 2007    Post subject: Neutral Light Reply with quote
I noticed that the neutral light on the CB4 is on no matter which gear its in, as long as the clutch is disengaged. Gets a bit confusing when im changing gear from first to second. A few times i've went into neutral then changed up to 3 thinking im still in neutral Rolling Eyes stupid i know but i was just woundering if it should be like this as the NSR only shows a neutral light when its actually in neutral.
Rides: Honda CB400 SF (ART can) - Citroen Saxo 1.1i SX
teampots
PostPosted: 18:11 - 05 Aug 2007    Post subject: Reply with quote
thats what its supposed to do, as in only come on when its in neutral
Current - Fazer 600
Prev - Bandit x2 (Killed) CB400 (Superfour) CBR125
Currently Restoring - Kawasaki S1 250 Triple (Slowly but surely)
AbiJ
PostPosted: 18:43 - 05 Aug 2007    Post subject: Reply with quote
From the description there seems to be a wiring fault as the neutral light should ONLY be on in neutral, clutch in or not (otherwise it wouldn't be a neutral light but a clutch in light).
Check the wiring from the switches and light, possibly a bad earth is causing the power to back-feed through the clutch lever switch causing the light to power on when the lever is pulled.
Abi.
'81 Yammi XJ750 Seca, oldie but a goodie.
Ichy
PostPosted: 19:28 - 05 Aug 2007    Post subject: Reply with quote
I'm guessing there's either an earthing problem or the switch is knackered. Try disconnecting it and shorting the contacts to see if it goes on and off.
djrichieb
PostPosted: 20:34 - 05 Aug 2007    Post subject: Reply with quote
I thought that it wasnt right.
Thanks for all your help everyone.
alun111
PostPosted: 07:48 - 06 Aug 2007    Post subject: Reply with quote
Not sure where the neutral indicator is on your bike but try and find it then trace the wires checking that no insulation has rubbed through shorting it out. This is what was wrong on my bike (bandit 400) and it cost me £60 to get it sorted as it involved them taking the tank off and everything to trace the wire.
The last post was made 19 years, 70 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 47.33 Kb
