CG125 jerks forward a bit when put in gear when cold:
deanoet
PostPosted: 20:26 - 05 Aug 2007    Post subject: CG125 jerks forward a bit when put in gear when cold: Reply with quote
is this right?
Start it up in neutral, clutch in, and put it into first, and it jerks forwards a little bit. It doesnt try to pull forward, it is almost like it engages for a split second then stops.
Have tried it on the stand, and the wheel doesnt turn when the clutch is pulled in and it is in gear, so the clutch is disengaging okay.
When it is just switched on as well so still a bit cold, it also stalls when put into gear, even with the clutch in, surely nothing is engageing with the engine, so there is no extra strain on it?
It only tends to do it when cold, once warmed up it doesnt do it at all.
New bike with 100 miles on the clock so wear and tear shouldnt be a problem. If this isnt normal i will give honda a ring tomorrow and see what they say.
2t-Screamer
PostPosted: 20:29 - 05 Aug 2007    Post subject: Reply with quote
every geared bike ive ever had (quite a few) has jerked when i put it into 1st on a cold engine, i wouldnt worry about it, i think its something to do with the clutch plates sticking together when there cold? although im sure somebody will correct me lol
visit Collective Knowledge
Jamie S
PostPosted: 20:30 - 05 Aug 2007    Post subject: Reply with quote
All of my bikes do it as well.
deanoet
PostPosted: 20:32 - 05 Aug 2007    Post subject: Reply with quote
wow, 4 minute response time... Smile
Thanx, puts my mind at rest. Smile
2t-Screamer
PostPosted: 20:36 - 05 Aug 2007    Post subject: Reply with quote
Embarassed makes me look kinda sad and friendless lol, i dont just sit here waiting for an oportunity to post (honestly i do have a life aswell) Laughing
Spoon261 This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
Spoon261
PostPosted: 10:19 - 06 Aug 2007    Post subject: Reply with quote
deanoet
I am slightly more away now (last post 3:25am).
When you have looked at my website, I believe the bike stalling when cold fault was due to the bike having the choke turned off to soon, its was almost ready to have the choke turned off and would seem ok idling, but as soon as you put it in gear it would stall.
The slight jerk when you put the bike in to gear, is probably normal, I have been riding for over 13 years now and my brain probably does not even register it anymore, since as people have said all their bikes do it.
But if it’s excessive, theirs something needed to be done.
Your engine is still new, only 100 miles so it’s no ware near run in, this could be affecting things.
The only things I can think of are clutch leaver might need the free play screw adjusting and the idle speed might need to be turned up, both are on my website in the servicing section.
Trixie
PostPosted: 10:35 - 06 Aug 2007    Post subject: Reply with quote
Before engaging gear for the first time, try holding in the clutch a few times beforehand. See if that helps. Thumbs Up
Dead nobodies in company cars...
Rookie
PostPosted: 10:40 - 06 Aug 2007    Post subject: Reply with quote
Spoon261 wrote:
deanoet
Wow, talk about overcomplicating things.
veeeffarr
PostPosted: 10:43 - 06 Aug 2007    Post subject: Reply with quote
Spoon261 wrote:
deanoet
I have got the same Honda CG125 as you, the latest model
I am trying to work out if what you describe is normal or not.
I need more information, but before I ask, can you have a look at my Honda CG125 website, since that explains lots of the choke related quirks of the latest model.
Choke information is on the General webpage of my site
https://hondacg125.awardspace.com/
Spoon: You are a tool.
OP: It is your clutch plates sticking together over night, this answer has been given too you already.
I've found on any Honda I've ridden (CG125, CLR125, NT650V, VFR800Fi) first from Neutral is always a bit clunky.
Change your oil and recheck you chain tension and if that reduces the symptoms. It is nothing to worry about though. My CG125-W did it all the time.
Honda aren't renowned for their smooth gearboxes Wink
Spoon261
PostPosted: 11:12 - 06 Aug 2007    Post subject: Reply with quote
Toby R
I see you had the 2001 Model Honda CG125, according to the motorcycle news review of the new model “have a vastly improved gearbox” compared to the old model.
https://www.motorcyclenews.com/MCN/bikereviews/searchresults/Bike-Reviews/Honda/Honda-CG125-1975-current/?&R=EPI-301
I have had no problems with the clutch when cold.
Never in over 10,000 miles, had the bike from new.
I would not change the oil at 100 miles without the advice from a dealer.
Their may be a special polishing oil in their to help the bike run in.
Chain tension, if its so far out its causing trouble at 100 miles, I would be amazed.
The Chain is an O ring type, not some cheap load of rubbish.
I did have to tighten it up a very few times when it was new, but it only slackened slightly, then I went for well over 5000 miles without having to adjust it.
The only way I could possibly imagine the chain has stretched allot at 100 miles is if the person is heavy and thrashing the bike.
But of course it’s always a good idea to check the chain tension, especially when its new and settling in.
The old model Honda CG125 might have had a lesser chain, non O ring? That would effect things. They cost a fraction of the price of an O ring and also last a fraction of the time.
veeeffarr
PostPosted: 11:39 - 06 Aug 2007    Post subject: Reply with quote
Didn't read the bit about it only doing 100 miles. Still, I wouldn't say it was a problem at all, it's happened on every bike I've owned.
T
Spoon261
PostPosted: 11:53 - 06 Aug 2007    Post subject: Reply with quote
T
You got me thinking, oil.
I would check the oil level, I did not mention it before since the dealer is supposed to instruct you on the routine checks when you receive the motorcycle, and one of those routine checks is to check the oil level.
The oil level is very important when the bikes new and running in, since if theirs a fault in the manufacturing process it could loose / burn oil, I would not want an engine that runs out of oil.
Of course the clutch uses the engine oil to lubricate itself.
Honda CG125 Website https://hondacg125.awardspace.com/
Honda CBF125, CBR125 & Yamaha YBR125 Website https://125ccbikeclub.awardspace.co.uk/
I have left bikechat forums, I do not read pm (Private Message)
veeeffarr
PostPosted: 12:00 - 06 Aug 2007    Post subject: Reply with quote
It's just the cold oil causing the plates to stick together
veeeffarr
PostPosted: 12:03 - 06 Aug 2007    Post subject: Reply with quote
Regarding the cutting out, you're not putting it into first with the sidestand still down are you? (Mind you, I can't remember my CG having a sidestand...)
T
KLR600
PostPosted: 12:05 - 06 Aug 2007    Post subject: Reply with quote
You do know that new chains stretch a bit right? Regardless of make or type? Every time I've replaced chain (always o-ring) and sprockets I've had to adjust the chain tension after 100/200 miles then it settles down and doesn't need adjusting for a while.
I've had this clunk on every bike I've ever owned or ridden but I find that having a slacker than usual chain makes it more pronounced.
<Take Cool Photos!>
Spoon261
PostPosted: 12:08 - 06 Aug 2007    Post subject: Reply with quote
In the middle of summer?
I totally understand what you are saying, the oil, the clutch and everything else is cold
In the middle of winter and if the bikes left out, this could be a problem.
But in the middle of summer, things would be warm enough to only very slightly show this fault.
Of course another make and model of bike could be a totally different story.
Trixie
PostPosted: 12:22 - 06 Aug 2007    Post subject: Reply with quote
I used to get this on my old CB, as I do with the TRX. Even in the summer!
If it's just the clutch plates, which it does sound like, there's nothing to worry about. As I said above, just engage the clutch a few times to loosen up the plates; that normally works for me.
Jamie S
PostPosted: 12:27 - 06 Aug 2007    Post subject: Reply with quote
Do you live in the USA or something, Christ , engine oil needs to be a LOT hotter than 20C for the clutch to perform properly.
Spoon261
PostPosted: 12:54 - 06 Aug 2007    Post subject: Reply with quote
I live in the UK
I have the same make, model and version of the bike as the person who has asked about a potential fault.
No one else appears to have the same make, model and version.
The clutch sticking when cold, could well be totally different on other versions and models of bikes.
I have also ridden another identical Honda CG125 bike and its clutch was identical to mine when stone cold and it was 3c outside (middle of winter) and in a warehouse type motorcycle shop.
The clutch sticking and operating it a few times before selecting 1st is a very valid piece of advice, it could be the clutch needs to run in. It could be it’s a slightly faulty clutch but within design parameters.
And remember I have said all along that you only need to do something about it if its excessive. I also said that mine might also be doing it, but its so minor I do not even realise it, if it was bad, I would well and truly no about it and do something about it.
What I latched on to at the very beginning was the stalling part, and suggested a solution.
And what non of you have said is about idle speed, it totally effects the gearbox and clutch. To fast or slow and it can cause trouble.
To fast and the clutch / gearbox / engine will overheat (clutch can spin dry = no oil), to slow and it can stall.
I can well and truly believe that some makes and models / versions of bike have this clutch stick problem when cold as a design glitch. If I was to list the amount of bikes and their gearbox and clutch design faults, I would be typing all day.
Finglonga
PostPosted: 13:16 - 06 Aug 2007    Post subject: Reply with quote
There is nothing wrong with the clutch, gearbox or bike at all. All wet clutches do it from cold or when they have been standing for a while. As said its the oil between the plates becoming viscous and sticking them together.
BEFORE you start the bike put it into first, pull the clutch in and roll the bike backwards and forwards a couple of times. Now put it back into neutral and start the bike and try it, there shouldn't be a clunk this time.
Andy Sez....
F.Y.Y.F.F.
Jamie S
PostPosted: 13:18 - 06 Aug 2007    Post subject: Reply with quote
But you get a "clunk" every time a gear is selected, only a slight one though.
Spoon261
PostPosted: 13:56 - 06 Aug 2007    Post subject: Reply with quote
T
Theirs no side stand
And even if you do obtain a side stand, it does not have an engine kill switch.
Spoon261
PostPosted: 14:06 - 06 Aug 2007    Post subject: Reply with quote
Yes I do no a chain normally stretches a bit when new and then settles down, that’s why I said it!
You do not appear to have owned a Honda CG125 new model, according to your details.
If you had, you would no a Honda CG125 accelerates so slowly and smoothly that the chain stretches no ware near as much as most bikes. It also lasts a lot longer as well.
I did not say it did not need to be adjusted at 100miles, I said it would not be so slack as to cause the fault!
veeeffarr
PostPosted: 15:00 - 06 Aug 2007    Post subject: Reply with quote
So what's this major magical change that completely transforms the Honda CG125 into this amazing machine?
As far as I know it's been practically the same design for 30 odd years, it's hardly a massive design change whatever it is.
The last post was made 18 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 136.49 Kb
