Spraying
shaun_04
PostPosted: 09:37 - 14 Aug 2007    Post subject: Spraying Reply with quote
I've recently resprayed my bike, but I have a problem: the finish on the lacquer is rough. I sanded each bit down, then applied primer, then used wet & dry, then painted, then used wet & dry, and then applied plenty of lacquer, but the finish is rough. Do I need to do something else now to get it smooth and shiny?
konsoli
PostPosted: 10:09 - 14 Aug 2007    Post subject: Reply with quote
smooth&shiny?
wey&dry for smooth..shiny..polish?
upload a pic of your bike when it's done so we can see =P
bladerunner
PostPosted: 10:37 - 14 Aug 2007    Post subject: Reply with quote
You might have needed to thin the clear coat down a bit more..but you can still mirror finish it with some wet and dry..id start with some 800 with plenty of soap to start with if its rough and you'll soon have it up to a good finish!!
shaun_04
PostPosted: 10:52 - 14 Aug 2007    Post subject: Reply with quote
bladerunner, I was using 1500grit, what do you think I should do to the top coat? - wet&dry and then t-cut or summat?
This is the first time that I have done painting, so would appreciate help from someone who knows for sure what he is doing.
andrew
Mister Road Rage
PostPosted: 11:26 - 14 Aug 2007    Post subject: Reply with quote
When you say plenty of laquer, how many coats did you put on?
If you put enough coats on, look into polishing compound, to get a mirror finish on mine i got polishing compound and used a pad attached to a drill. It took ages but in the end it looked pretty near showroom quality.
Big Pete
PostPosted: 11:46 - 14 Aug 2007    Post subject: Reply with quote
G3 cutting compound form Farecla (you can get from car places) on a soft cloth plus lots of elbow grease, (or better still an electric buffer ) will bring it up.
Trust me, I`m an engineer
GarageOfPower.co.uk
shaun_04
PostPosted: 15:40 - 14 Aug 2007    Post subject: Reply with quote
Yea, I think I put enough coats on to use the polishing/buffing method.
Thanks Andrew and Pete.
edit: The lacquer said allow 2 weeks to harden, should I buff it now, or wait another week 'til it has hardened?
Big Pete
PostPosted: 16:11 - 14 Aug 2007    Post subject: Reply with quote
If its 2 pack I've buffed it after as little as 2 hours, and if you have proper drying gear you can do it in an hour or so. If its cellulose, best to leave it for a week or so.
GarageOfPower.co.uk
andrew
Mister Road Rage
PostPosted: 16:13 - 14 Aug 2007    Post subject: Reply with quote
To be honest, i don't know enough about it to be able to answer that.
I know that after spraying you're meant to bake the finished piece before doing anything with polishing compound but i think it really depends on who you talk to.
If you can wait, i'd say wait and do what the can suggests but i'd be tempted to put it all somewhere hot like an airing cupboard then give it a go a few hours later.
Pete is probably the best person to ask. Very Happy
The last post was made 18 years, 290 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 57.87 Kb
