Suzuki RG/RGV 250
.Chris.
PostPosted: 09:38 - 14 Aug 2007    Post subject: Suzuki RG/RGV 250 Reply with quote
You may remember I posted in a 'dream bike' thread that I like these bikes, especially the naked 'wolf' version. Following on from my thread in the workshop section, it seems they could be semi-restricted by a switch temporarily disconnecting the powervalve system, so I could actually ride one. Amazingly the insurance isn't too bad either.
So, a couple of questions:
Has anyone got or had one? Any tips or wisdom you wish to impart to me about them? What are they like to ride?
Oh yes, and what's the difference between the RG and RGV - Used Bike Guide is a little unclear as it doesn't have any pictures.
Thanks Very Happy
Edit: there's a gorgeous one on ebay at the moment - https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280142614654
Chris
1985 Kawasaki Z550F
qthetape
PostPosted: 10:03 - 14 Aug 2007    Post subject: Reply with quote
rg's old but fun
https://www.altavista.com/image/results?itag=ody&q=rg250&mik=photo&mik=graphic&mip=all&mis=all&miwxh=all
rgv's sexy but probably been thrashed and parts are tricky to find
https://www.altavista.com/image/results?itag=ody&q=rgv250&mik=photo&mik=graphic&mip=all&mis=all&miwxh=all
if its a dream bike your after, go for the rgv
as with all 2-strokes use the best oil you can afford and check the pumps working from time to time
edit:thats quite an old one on ebay, look for the gull swing arm later one with both tail pipes on the right
imo - the nc30's nicer and sounds unique
found something better to do with my time
Zen Dog
PostPosted: 10:09 - 14 Aug 2007    Post subject: Reply with quote
I always loved these too, i really wanted the 125 as my learner bike but they were rarer than hens teeth. But the 250 version...
I want I want I want I want..... Crying or Very sad
Zen Dog
.Chris.
PostPosted: 12:48 - 14 Aug 2007    Post subject: Reply with quote
Thanks for that qthetape. I don't know for how long they made the wolf version (it's the only one I'm interested in), and can't seem to find much info on the internet. Have you any ideas?
Chris
1985 Kawasaki Z550F
EuropeanNC30R...
Gay Hairdresser
PostPosted: 13:07 - 14 Aug 2007    Post subject: Reply with quote
It'd be a bad idea buying one just to disconnect the powervalve.
a) It would likely run like shit, these bikes tend to blow up when that happens, you can't get away with as much abuse as you can on a 4-stroke.
b) The RGV does 25mpg, and consumes a litre of synthetic every 200 miles (about £9-£10). You would effectively be paying Ducati 916 running costs for a bike with the same power as a 125, that runs like crap.
PostPosted: 13:10 - 14 Aug 2007    Post subject: Reply with quote
IIRC the wolf one has RWU forks and is a bit crap. They only made it for a year or so.
Personally I'd buy a fooked later RGV and stick a streetfighter headlight on it. If you can find one!
Also bear in mind that they are not every day bikes (as much as Maurice will try to convince you! Wink )
They need lots of looking after, with expensive synthetic oil required. Mine absolutely drinks oil, and is impossible to ride in town without mullering the clutch.
The standard ones have crap powervalves which corrode and then fall into the cylinders, destroying the engine. Mine shattered a piston after three trackdays, and I couldn't ride it on the road before that happened through fear of knackering the clutch. Mine has Aprilia RS250 powervalves (Aprilia bought the engines from Suzuki), and has had only very minor tuning.
The mains on mine were also on the way out, so I recently had the engine rebuilt including a crank rebuild, new mains, new big ends, and an entire new top end. This cost £400.
I'm currently in the process of putting the engine back in the frame after the rebuild, and will need to get the bike dynoed to get the powervalves set up properly again. They are good bikes, but no matter what anyone tells you, its a crime to use them to commute etc.
What they really like is a smooth twisty A or B road, or a trackday.
Oh yeah, and the RG is a parallel twin and much much older, and much much uglier.
My RGV is the M model iirc.
https://www.marjay.co.uk/photos/RGV250-4.jpg
https://www.marjay.co.uk/photos/RGVCad2.jpg
My advice would be, if its a second bike or pure toy, then go for it. If its an only transport type of bike, then steer well clear unless you're very rich. If you are very rich, then buy a CBR600 for daily use, and have the RGV for the track.
Anything else you'd like to know about them?
PostPosted: 13:15 - 14 Aug 2007    Post subject: Reply with quote
I read your post a bit more thoroughly:
If you buy one and disconnect the powervalve I'll personally come and stomp on your head. These are rare bikes now, and enthusiasts are aching to get hold of decent ones. If you disconnect the powervalve, you'll destroy the midrange but keep the top end, meaning the bike won't be restricted. Also As Maurice says you'll ruin the fuelling and therefore the lubrication probably completely destroying the bike in the process. To buy one of these and restrict it to 33bhp is like using the mona lisa to wipe your arse.
Don't bother, buy a GS500 or a CB500 to restrict. Buy an RGV when you can afford to keep it as a toy. Not before.
{edit} a tweaked RG125 would probably be able to approach 33bhp... {edit}
EuropeanNC30R...
Gay Hairdresser
The wolf wasn't crap, just an unfaired early RGV. It's said the USD's did more for the looks than the handling; they all corner brilliantly.
Very rare though.
EuropeanNC30R...
Gay Hairdresser
PostPosted: 13:20 - 14 Aug 2007    Post subject: Reply with quote
On the model I had (k) I think it'd just mean the valves never opened so you would just get the bottom end (urghh Sick). But I think there were 3/4 different powervalve revisions through the years, may depend which model you get what you can restrict.
PostPosted: 13:27 - 14 Aug 2007    Post subject: Reply with quote
Very rare though.
I think they only made 45bhp too... there were a number of reasons why they are crap, but I can't remember them all... Smile
EuropeanNC30R...
Gay Hairdresser
PostPosted: 13:32 - 14 Aug 2007    Post subject: Reply with quote
All the early Jap RGV grey imports were 45bhp restricted, so its more of a grey thing than the wolfs fault Smile
Tarmacsurfer
PostPosted: 13:45 - 14 Aug 2007    Post subject: Reply with quote
Reminds me, need to dig out the old 125 Gamma I've got in the garage. Whoever chose the turqoise paint job needs to be shot, bike itself is OK though.
I'm immortal. Well, so far.
.Chris.
PostPosted: 20:28 - 14 Aug 2007    Post subject: Reply with quote
Marjay, I think you misunderstood what I meant about disconnecting the powervalves. What I meant was that I'd have a switch so I could disconnect them if I got pulled by the old bill and asked about restriction. Basically an 'emergency' restrictor that would probably never get used.
I wouldn't ride it around town very much as I'll be keeping the RXS100 for that sort of stuff. Bikes are my toys anyway, because I have a car as well so practicality isn't really too much of an issue. However I take your point though.
I suppose I like the wolf because it's very small and light, fast, 2t, and looks so damn cool. Tbh I don't really mind about having only 45bhp as it'd still be 4 times what I'm used to! I'm sure it'd be possible to convert it if I really needed the extra power at some point?
What's the performance like? Have you any experience with the 45bhp versions? Would I be right in assuming that the engines last a bit longer in 45bhp form than 55/60bhp?
I had thought about the TZR250 and didn't know they did a naked version - I'll take a look at the R1-Z. What would be the advantages of getting a TZR over the RGV?
Chris
1985 Kawasaki Z550F
EuropeanNC30R...
Gay Hairdresser
PostPosted: 21:03 - 14 Aug 2007    Post subject: Reply with quote
The vj21 models only made 50bhp unrestricted. They weren't much slower than the 91' onwards models, due to being 10kg lighter and 5bhp down.
I had a Jap import model vj21 rgv (what the wolf was based on), it was a bit unknown how they were actually restricted. I fitted a UK cdi and UK speedo. Not sure if that de-restricted it or not to be honest.
Good thing I found with the RGV was that it mostly looked and sounded like a 125.
PostPosted: 21:22 - 14 Aug 2007    Post subject: Reply with quote
I've owned both an RGV and a TZR and I'd definately say the TZR had a better engine. I might even go as far as to say that if they were both new, the TZR is a better bike.
The RGV is more powerful, but all the power is at the top end and it really needs thrashing. The handling is only marginally better than the TZR, which is odd as my TZR was fairly well fooked.
The RGV is basically a 250GP bike with lights, and the TZR is a fast road bike. The R1Z I can imagine is a bloody brilliant bike.
Also the Yamaha SDR200 (if you can find one) would make a great toy too. Rare, but an absolute hoot from what I can gather.
The RGV is much much more serious, but its a better bike on the track. My RGV made about 60bhp before it popped, and as standard the M (USD fork) Models make about 55bhp.
SDR200:
https://home.planet.nl/~jgtdalen/normal/Yamaha-SDR200-1987.jpg
R1Z:
https://www.elliottmc.co.uk/pics/1566.jpg
PostPosted: 21:26 - 14 Aug 2007    Post subject: Reply with quote
Oh yeah, and the wolf only has one brake disc!
PostPosted: 21:49 - 14 Aug 2007    Post subject: Reply with quote
From the mid 80s onwards onwards any Japanese market 250 would be restricted to 45hp.
johnsilva
PostPosted: 12:01 - 15 Aug 2007    Post subject: Reply with quote
Get a KR1S!!!!
Current Bikes: ZX7R P5; KR1S C2; GPX250R F3
Previously: CBR400RR-R; YQ50 Aerox
PostPosted: 12:05 - 15 Aug 2007    Post subject: Reply with quote
johnsilva wrote:
Get a KR1S!!!!
Laughing they are even more rare, fragile and sought after than the RGV!!
Tarmacsurfer
PostPosted: 14:41 - 15 Aug 2007    Post subject: Reply with quote
MarJay wrote:
johnsilva wrote:
Get a KR1S!!!!
One of them in the garage as well Wink
The ex has a thing for 2 strokes Rolling Eyes
.Chris.
PostPosted: 14:59 - 15 Aug 2007    Post subject: Reply with quote
Don't like the look of them as much as the RGV, sorry!
Chris
1985 Kawasaki Z550F
The last post was made 18 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.94 - MySQL Queries: 13 - Page Size: 123.03 Kb
