Dim Head lights? NSR 125
rosshandby
PostPosted: 02:30 - 05 Nov 2003    Post subject: Dim Head lights? NSR 125 Reply with quote
Can anyone tell me why the headlights on my NSR are so dim? Ive charged the battery up lots, and still the lights are very dim (on all settings) even when fully revd.
Any help would be greatly apreciated
Does anyone else have this problem?
one1895
I liked BCF so much I made my own copy
PostPosted: 02:46 - 05 Nov 2003    Post subject: Reply with quote
What year NSR do you have? Are any of the bulbs blown? Have you checked for loose wires? Do they get brighter on full beam and change brightness on different settings?
There should be one tiny bulb (i think) and one main bigger one, in each section of your headlights.
I just replaced my main 25w bulbs on my NSR today as a matter of fact, what a farcing fiddle. Mad
Hull & Yorkshire Bikers - Sheffield & Yorkshire Bikers - Manchester Bikers - Nottingham Bikers
GFK
PostPosted: 03:47 - 05 Nov 2003    Post subject: Reply with quote
NSR headlights are nothing spectacular at the best of times...
rosshandby
PostPosted: 11:44 - 05 Nov 2003    Post subject: Reply with quote
Its a 2002 model, the lights are so dim on main beam and dipped, they look like side lights!!!will check for loose wires, but all bulbs work
ProXimaCore
Dougal
PostPosted: 18:50 - 05 Nov 2003    Post subject: Reply with quote
I just changed my bulbs from 25w to 45w on my NSR. Just go into your local bike shop and take in the bulb and they'll give you the ones you need. Just say you need 45watt. Or unless someone knows the proper name of the bulb type...... The bulbs are real easy to get out. You can get them out by turning the handlebars out the way for each light and remove the rubber sock thing that covers it and then twist it out. It's real easy, just look and you'll see. Didn't make it significantly better but it's still an improvement.
Scotty
Scooter Boi
PostPosted: 18:52 - 05 Nov 2003    Post subject: Reply with quote
Pats shiny new headlight unit Cool
Much brighter with the xeon bulb thingys Very Happy
all two of them on normal beam, then high beam switches to one bulb and goes super bright,
(and no its not my dodgy wiring for once)
Regards
Scott
The last post was made 22 years, 289 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 47.43 Kb
