Losing Power?
zaknafien
PostPosted: 20:07 - 05 Nov 2003    Post subject: Losing Power? Reply with quote
Got a little problem with the cat Sad
As I’m riding along it's losing power for about a second then kicking back in again, at first I thought I had a sticky link in my chain or something but then I noticed the tacho drops off to nothing at the same time as it losing power and then comes back up when the power kicks in.
Anyone have any idea what it could be? I’m guessing plugs or carbs?
02 Firestorm.
WildGoose
White Van Man
PostPosted: 20:12 - 05 Nov 2003    Post subject: Reply with quote
either of those i'd check
carbs were always giving me grief on my bike giving similar symptoms, but could quite easily be the plugs, do a plug chop...
then if the plugs are ok, maybe strip and clean the carbs
when was the last service?
PostPosted: 20:12 - 05 Nov 2003    Post subject: Re: Losing Power? Reply with quote
If the tacho is dropping off then I would suspect that it could be an electrical problem.
Does it happen after the bike's got wet recently or any other obvious signs?
zaknafien
PostPosted: 20:15 - 05 Nov 2003    Post subject: Reply with quote
No doesnt seem weather related at all. Gave it a wash a week ago and it's only started the last 2-3 days.
02 Firestorm.
Racer X
PostPosted: 20:29 - 05 Nov 2003    Post subject: Reply with quote
did any water get in your fuel tank or engine?!?!
check your plugs if they are good check the ignition to see if spark is consistent, then check your carbs clean if necessary.
Good Luck
< Live To Ride & Ride To Live >
TiN
Pocket Tin
I didn't realise that the 'Cat had that much power to lose. Razz
Anyhoo, could it be fuel tap/filter/hose related? Is there a certain rev range in which these problems occur?
TiN
dotgems.net
Hex
Party Boy
PostPosted: 20:41 - 05 Nov 2003    Post subject: Reply with quote
It doesn't Tin thats why he's noticing it. Laughing
This may sound like a really daft question but have you touched anything recently on the bike that you wouldn't normally?
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
PostPosted: 20:50 - 05 Nov 2003    Post subject: Reply with quote
The tacho dropping right down tends to suggest that it isn't sparking. Suggests either power to the cdi unit, the triggers from the cdi unit or a friend cdi unit.
Robby
Dirty Old Man
PostPosted: 23:21 - 05 Nov 2003    Post subject: Reply with quote
Also check you don't have a loose or corroded battery terminal.
The last post was made 23 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.11 Sec - Server Load: 0.96 - MySQL Queries: 16 - Page Size: 63.21 Kb
