Tank drain repair - petrol safe glue?
FreshAL
Sir Crashalot
PostPosted: 12:09 - 21 Aug 2007    Post subject: Tank drain repair - petrol safe glue? Reply with quote
Hi,
The drain pipe from the rim around the filler on the petrol tank on my curvy SV650 has snapped off.
Is this repairable or is it time for a new tank? Could I bodge it with silicone sealant or something? I'm pretty skint at the moment.
This is getting close to being the final straw with this bike, I think it's cursed. Evil or Very Mad
ZRX61
Victor Meldrew
PostPosted: 14:26 - 21 Aug 2007    Post subject: Reply with quote
Don't spill any fuel & it won't be a problem.... Wink
FreshAL
Sir Crashalot
PostPosted: 15:04 - 21 Aug 2007    Post subject: Reply with quote
It's not fuel that's the problem ,it's rain water.
Got stuck at work till 10 last night cos the tank filled up with water Sad Known fault on SV's
Bendy
Mrs Sensible
PostPosted: 15:27 - 21 Aug 2007    Post subject: Reply with quote
There are two bashed-in but still fuel / watertight tanks in the back garden if you need a quick solution. Sure Luke wouldn't mind you borrowing one.
Big Pete
PostPosted: 11:48 - 22 Aug 2007    Post subject: Reply with quote
Petseal or leak fix are epoxy fillers (available from car places) that will do the job. most of the plastic metal type 2 part mixes will work as well. I once fixed a tank that gave up at a rally with plastic metal and repair mesh, it lasted fine for at least 2 years afterwards at which point the rest of the bike gave up.
You need to sand all the paint off around the repair area and wipe it down with meths to degrease it, as petrol has atendency to creep you may well need to do it a couple of times. Put on a couple of thin layers rather than one big glob. warming things up with a hairdryer or a hot air paintstripper help as well.
Trust me, I`m an engineer
GarageOfPower.co.uk
The last post was made 19 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 42.91 Kb
