| Erect Bal Bal |
 Erect Bal Bal L Plate Warrior
 Posted: 22:14 - 15 Aug 2007 Post subject: Nsr 125r 51 plate charging probs |
Hi there i am hoping someone can help me.I am 35 years old and not new to bikes but this has got me stumped.I have just brought a 51 plate nsr125r to run to and thro work as i dont want to put to many miles on my RD500.The nsr wont hold a charge the battery was flat so i got a new one.This was fine for 2 days but then the bike started to cut out on low revs and i just got it home.Put my volt meter on the battery with the bike running and it was showing just over 13 volts but the moment i rev it it drops down to 7 vollts so it is doing the reverse of what it should do.Found the regulator rectifier and it was hot.Got a second hand one from e-bay which came to day fitted it and it still does the same.So could some one please point me in the right direction.Many Thanks  |
| alains |
 alains World Chat Champion
| Erect Bal Bal |
 Posted: 12:12 - 20 Aug 2007 Post subject: |
I have done the checks that you have said and every thing is fine the number on the serial is 01.Please help as i am at a total loss.  |
| Trixie |
 Trixie World Chat Champion
| alains |
 Posted: 13:03 - 20 Aug 2007 Post subject: |
ok . now unplug the wires on to positive of the battery . put it in charge with an outside charger during 6-8 hours at low intensity (0,5 to 1 Ampère) when finish , unplug charger , check voltage and if it's less than 12.9 Volts change battery . if ok , let it for 2-3 hours then check voltage again and if you've lost 0,2Volts or more change your battery
i will explain : 12V batteries ares composed by 6 plates covered with stuff , as new each element is 2.2Volts end of charging ,1.9 Volts end of discharging (13,2 & 11,4 volts) and the capacity is proportional at the stuff . with age & use the stuff goes off the plates so the capacity will fall down and the voltage as well , and we say "battery doenot keep charge" , this is why it's important to make 2 mesurements spaced at least 2 hours and see if the voltage get lower ____________________ the worst day fishing is better than the best day working |
| Erect Bal Bal |
 Posted: 19:30 - 20 Aug 2007 Post subject: |
I have fitted a brand new battery and have put it on my optermiser for 48hrs there looks like there was a alarm fitted at some time of its life a datatag one and some won has cut it out so i am going to get a new loom from e-bay and change it then see what happens  |
| Erect Bal Bal |
 Posted: 15:47 - 21 Aug 2007 Post subject: |
Now it has lost its bloody spark.Just like me is the cdi the cause please help.Or if any wants to buy it thay are more than welcome to make me a good offer. |
| Erect Bal Bal |
| Smiffy1203 |
 Smiffy1203 Nitrous Nuisance
 Posted: 16:32 - 21 Aug 2007 Post subject: |
not sure if they have fuses but check them if they have, my mate had the exact same problem on his Evo 5 turned out to be the battery fuse after changing the battery and alternator(what a ball ache job on them!!)  |
| Erect Bal Bal |
| Smiffy1203 |
| johns |
 johns Two Stroke Sniffer
 Posted: 21:14 - 21 Aug 2007 Post subject: |
may be the batter is flat and need a new one as it got any water in it  |
| Erect Bal Bal |
 Posted: 21:21 - 21 Aug 2007 Post subject: |
It has got a new battery on it and it is full of acid it charges up to 13.4 on my charger let it stand and it shows 12.9. Two hours later it shows 12.7 this is the reading i get when the battery is not on the bike  |
| alains |
| Smiffy1203 |
| johns |
 Posted: 15:51 - 22 Aug 2007 Post subject: |
what charges is it a bike one or car one  |
| alains |
| johns |
| Erect Bal Bal |
The last post was made 19 years, 65 days ago. Instead of replying here, would creating a new thread be more useful? |
