Jinlun 125-11 - Clicking noise from wheel/engine area !????
johninhere
PostPosted: 14:40 - 15 Aug 2007    Post subject: Jinlun 125-11 - Clicking noise from wheel/engine area !???? Reply with quote
Hey,
Can anybody help ...
Clicking noise sounds like a chain slip as if on a push bike !! (is this possible on a motorbike >???, poor power , general unsafe feeling !!!
I have checked the Chain and made sure its tight enough etc... nuts are tight on back wheel !!!
Back wheel is a bit off in alignment but I Cannot get it better !!.
Could it be my Sprockets !!??
I am very new to bikes and engines so please be simple !!!
Cheers
Steve
Steve125
PostPosted: 05:10 - 22 Aug 2007    Post subject: Reply with quote
Clicking noise could be many things on the Jinluns since they are built with such low quality nuts and bolts. The gear boxes tend to become quite loose after a while, as do the bolts. You should probably do a complete check on the bike to make sure all the bolts are tight. Check your crash bar to make sure it's secure, as that is a common thing to come loose.
It's important to get the back wheel alignment right. There are arrows on the axle bolts, just match them up either side when adjusting the chain, it's best to have the back wheel off the ground when doing this, so you can spin the wheel to make sure the chain is adjusted right.
The last post was made 19 years, 68 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 31.36 Kb
