Clutch cut off switch for MOT??
Dazbo666
PostPosted: 13:26 - 22 Aug 2007    Post subject: Clutch cut off switch for MOT?? Reply with quote
I was disconnecting the clutch lever and clutch cable on the GPZ in an attempt to lubricate the sleeve around the cable. The clutch lever had been getting increasingly harder to pull, and I realised it probably hadn't been checked since the last MOT in October 2006
I found out that the clutch cut off switch is damaged... the little plunger part of the switch that protrudes to the back of the clutch lever was cracked, and fell off when I removed the clutch lever. I've also drawn a blank so far today trying to get a replacement.
So does anyone know if it's a requirement for the switch to be present/working - and either way, anywhere I can order one online??
Word of the day : DILLIGAF
Liamo
PostPosted: 13:46 - 22 Aug 2007    Post subject: Reply with quote
Living in Ireland, I know nothing about bike MOT's (as we dont have them over here) but seeing as how they're not fit to every bike, I dont see how the tester would know if yours should ahve one or not ..
T1z3R
PostPosted: 13:49 - 22 Aug 2007    Post subject: Reply with quote
if this is to be believed then its not tested.
ive got a haynes book that tells you whats checked and i dont recall seeing it listed there either.
duck my sick!
Dazbo666
PostPosted: 13:56 - 22 Aug 2007    Post subject: Reply with quote
Sounds promising so far Thumbs Up
The last post was made 19 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 39.86 Kb
