nsr125 wont start
steve-h
PostPosted: 14:47 - 12 Aug 2007    Post subject: nsr125 wont start Reply with quote
as im just starting out in the 2 wheel world i got my hands on a 2001 nsr125r that needs some work doing to it, it needs front fairings,screen,clocks and a few other things
but my first problem is getting it to run, it turns over fine on the starter button but thats it
is there anything on these bikes that would make it fail to start
what should i be checking?
like i say im new to bikes so any help would be nice
thx in advance
steve Very Happy
Handsome
PostPosted: 14:49 - 12 Aug 2007    Post subject: Reply with quote
Check plug, coil and HT lead...Have replaced these three in the past...
May also be the side stand switch...
steve-h
PostPosted: 17:37 - 12 Aug 2007    Post subject: Reply with quote
well there is a blue spark from the plug so maybe ill check the fuelling side now
alains
PostPosted: 19:07 - 12 Aug 2007    Post subject: Reply with quote
check if your stand is up . if it's down, as soon as you engage a gear , the engine will stall
steve-h
PostPosted: 19:12 - 12 Aug 2007    Post subject: Reply with quote
yeah the stand was down but then i put it up and still the same
alains
PostPosted: 19:30 - 12 Aug 2007    Post subject: Reply with quote
adjust pilot screw at 2 1/2 turns out
start on choke let it turn until the engine begin to stuff , apply a slight acceleration and take choke off , keep it running 2000-3000 rpm until the temperature needle enter the white zone , release handle then adjust idle at 1500 rpm with the idle screw (the one with the spring)
if you cannot do that , i recommend to clean : tank (tap) , air box foam and carb . obviously a new plug is mmuch better
Evo
PostPosted: 19:14 - 13 Aug 2007    Post subject: Reply with quote
Aslong as it's in neutral, can't see how side stand switch would effect it.
Take your airbox off, put your hand over the carb and try to start up. You should feel fuel passing over your hands.
That confirms fuel is through the carb as a start.
You could take your carb off and remove your reed block and check the reed valves aswell.
If the bike turns over fast enough, checked battery with multimeter ect..
You can also try bumping it off, that'll rule things out if it does or doesnt go.
Obviously make sure youve got fuel and a spark(you've done) first before anything.
Bikes owned
1989 VFR 400 RR NC30
steve-h
PostPosted: 17:41 - 22 Aug 2007    Post subject: Reply with quote
ok ive checked fuel is getting to carb
there is a spark which is blue
ive got the manual from this site(is it ok for a 2001 foxeye model?) and im going to check some electrics
failing that im completey stumped
any1 got some other suggestions or what the readings should be
from the cdi and so on
steve
fluid
PostPosted: 22:40 - 22 Aug 2007    Post subject: Reply with quote
Have you checked the kill switch?
It's amazing how many people (including myself) overlook this.
st3v3
PostPosted: 22:53 - 22 Aug 2007    Post subject: Reply with quote
It's trying to start, not electrics.
If it's starting, fuel's getting to the engine, might be shit in carb.
befdelta7
PostPosted: 22:55 - 22 Aug 2007    Post subject: Reply with quote
is there compression in the cylinder? take out the plug(put it on the floor so you dont shock yourself) put your thumb over the plug hole and press the starter if you feel nothing your rings have gone. if you feel like your thumb is going to be given a love bite... stop! you've got compression.
failing that i dont have a clue, other than whats been said in the above posts.
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
alains
PostPosted: 23:00 - 22 Aug 2007    Post subject: Reply with quote
if you've got a nice blue spark and fuel line ok , no reason to do not start . try a new plug otherwise it's may be the float valve which is stocked
The last post was made 19 years, 56 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2 - MySQL Queries: 13 - Page Size: 70.53 Kb
