Right... Need a shed...
krebsy
PostPosted: 12:14 - 23 Aug 2007    Post subject: Right... Need a shed... Reply with quote
moving house to a much nicer area but losing the Garage which was the biggest benefit of the house. Having to find a small but secure bike shed/lockup thing that'll fit in the garden and won't overstretch the budget. I'll be replacing the rear fence to give proper gated access to the rear, but until then the bike'll have to live in a mate's garage (10 min walk away every morning and evening) or I'll have to park it out front.
I need a recommendation or two. Seen one or two things that seem to fit the bill, but lothed to fork out the £750 or so I've been quoted. I could always build a lean to/pergola and slap some plastic roofing over it but would like something where I can hide the bike away and put tools and stuff.
Any thoughts?
Ta,
K.
1280 x 1024.
daesimps
PostPosted: 12:42 - 23 Aug 2007    Post subject: Reply with quote
I just had the very same issue. Ended up going to a local wood merchant who custom built me one.
It is 9' x 5'5" and 6' high. It is built out of 3/4" board with a 2" base. It's like a nuclear bunker. Cost me £400 including him custom building it, treating it and erecting it for me on a Saturday morning (took 3 people!).
It seems very secure and not likely to ever be moved.
If it ain't broke, fix it till it is!
MaybeGuy
PostPosted: 12:45 - 23 Aug 2007    Post subject: Reply with quote
£350 ish for a metal shed from B&Q what i just got.
https://www.gardenbuildingsdirect.co.uk/images/products/billyoh/dubais.jpg
thats what i just got.
you can fit 3 bikes in with just enough room to work on 1 in there.[/quote]
veeeffarr
I'm in this situation as well apart from I live in a rented shared house Sad
Getting a big bin full of concrete and loads of almax gear though soon, but would like a cover really.
T
Trixie
PostPosted: 13:49 - 23 Aug 2007    Post subject: Reply with quote
When I was in a similar position I was looking at sheds from B&Q as mentioned above, and also metal garages (and sheds) from Argos, like this:
https://www.argos.co.uk/static/Product/partNumber/7051629.htm
and
https://www.argos.co.uk/static/Browse/catalogId/1500000701/identifier/8963125/Trail/C%24cip%3D1500006333%3EC%24cip%3D1500006434%3EC%24cip%3D1500006438.htm
Dead nobodies in company cars...
cestrian
PostPosted: 15:35 - 23 Aug 2007    Post subject: Reply with quote
A 6'x4' or 7'x5' shed would only cost about £125 tops. It will need a ground anchor installed but if the shed needs a concrete floor, the ground anchor could easily be installed as the concrete is setting. Easy to make a cheap shed alarm too.
LikeyLicky
PostPosted: 06:09 - 24 Aug 2007    Post subject: Reply with quote
I had this one 4 months ago when it was £400. Done it all myself and took 2.5 days to do. Fantastic shed too
https://www.argos.co.uk/static/Product/partNumber/7052037/Trail/C%24cip%3D1500006333.Garden%2C%2BDIY%2Band%2Bleisure%3EC%24cip%3D1500006434.Sheds%2Band%2Boutdoor%2Bbuildings%3EC%24cip%3D1500006438.Metal%2Bsheds.htm
Theory PASSED - 24/04/07
CBT PASSED - 28/04/07
Practical PASSED - 18/05/07
krebsy
PostPosted: 10:32 - 24 Aug 2007    Post subject: Reply with quote
I'm limited on space and the orientation of the garden. I'll need to fit a new fence, double gate and then add the shed onto some hard standing. trying to keep it down to 1.5x3m or less.
I've 2 areas I can put it, one at the bottom of the garden (giving a shallower entrance angle) or the other which would sit on a gravel area but would be at 90 deg. to the path. I'll be coming in and out from the right hand side. Option 1 would be easier to get the bike in, but option 2 would mean it'll be easier to turn it around (though would have to scrifice 2 to 4 trees to do it.
Hmm.
K.
1280 x 1024.
Tango675
PostPosted: 12:27 - 24 Aug 2007    Post subject: Reply with quote
Ill come and give you a hand.
Need practice as I will have to get a new shed for my bike's Smile
Somebody give that windup merchant a torque wrench..
Kal
PostPosted: 13:00 - 24 Aug 2007    Post subject: Reply with quote
If you are anywhere near Watford: Off of the VDub forum
Kal...
cestrian
PostPosted: 14:34 - 24 Aug 2007    Post subject: Reply with quote
No ground anchor = stolen bike.
krebsy
PostPosted: 11:31 - 26 Aug 2007    Post subject: Reply with quote
Well, currently it's in a locked garage with Anchor so will need to put it in a secure shed type thing with alarm+anchor and locked garden gates....
K.
1280 x 1024.
cestrian
PostPosted: 11:56 - 26 Aug 2007    Post subject: Reply with quote
No such thing as a secure shed. If 'they' want your bike they'll take it regardless what you do to secure it. All you can do is make life hard for them and ensure that if someone does try to nick it, you know about it.
You can make an effective shed alarm from an alarm horn, a charged battery, a switch, some wire and a piece of stiff copper wire.
Good luck
Walloper
PostPosted: 15:17 - 26 Aug 2007    Post subject: Reply with quote
You only need one of these fitted. Thumbs Up
The last post was made 18 years, 183 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 80.8 Kb
