| Irezumi aka Reuben |
 Irezumi aka Reuben Carrot Top
| hmmmnz |
 hmmmnz Super Spammer
| iooi |
 iooi Super Spammer
 Posted: 09:49 - 25 Aug 2007 Post subject: |
Temp sensor will not cause bike to overheat though.
Could be things are getting a bit bunged up try reverse flushing the system and making sure the rad is clear. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Finglonga |
 Finglonga World Chat Champion
| iooi |
 iooi Super Spammer
 Posted: 12:59 - 25 Aug 2007 Post subject: |
Good Point.
Op does say teamp gauge is dead. but what has made op think its overheating.
Just wonde if its a case of a blown head gasket ? ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Odie |
 Odie World Chat Champion
| MementoMori |
 MementoMori World Chat Champion
| Odie |
| bish777 |
 bish777 World Chat Champion
| Odie |
There is a gap of 223 days between these two posts... |
| BikerFSU |
 BikerFSU L Plate Warrior
 Posted: 09:20 - 09 Apr 2008 Post subject: CX overheating |
the radiator fan could have shattered. they are known for fraturing around the hub and then flying apart while the engine is running. the bike can still run for awhile after but it with act up. try checking your fan.
to check your thermostat, take it off the bike and suspend it in boiling water, once it gets hot enough, you can see it open itself up. depending how far it opens determines how good it is. i dont have my manual on me right now to look up how far it needs to open to be good.
the CX's are known for the mechanical seal failing...but other than that, they are rather indestructable. if the seal fails, you'll know it because your oil and radiator fluid will mix. so check your oil. a new mech seal is about $60-$70 usd. to change it, you got to remove the engine from the frame and remove the rear cover. the mech seal fails usually from the ceramic in it fracturing.
i own several dozen old bikes including two '80+'81 cx500c. which one of them overheated and quit running, thermastats fine, oil and water are still seperate, engine turns over with a wrench but not with the starter. i got a feeling it was the radiator which needed work but i havent tried starting the bike yet... any suggestions? any questions for me are answers to my questions can be sent to [email protected] |
| Bru |
 Bru Trackday Trickster
| Odie |
 Posted: 09:18 - 10 Apr 2008 Post subject: Re: CX overheating |
| BikerFSU wrote: | the radiator fan could have shattered. they are known for fraturing around the hub and then flying apart while the engine is running. the bike can still run for awhile after but it with act up. try checking your fan.
Change the starter, they can be a problem with age, as for the fan shattering, never known one to, drop off because the bolt holding them on has come undone, loose a bade or two but never shatter, and yes you would know if it went, you would have coolant every-where and bits of plastic in your legs!
try using a yamaha mechanical seal, they are only £15 (england dont you know old boy)
other problem over heating is that your battery could be on the way out, sends wierd readings to the voltage stabiliser and temp gauge, didnt believe it myself till i saw it! ____________________ You are so ugly when you were born the doctor said "I?m gonna drop it, if it falls is a rat, if it flies is a bat." |
The last post was made 18 years, 204 days ago. Instead of replying here, would creating a new thread be more useful? |
