| Loaney010 |
 Loaney010 L Plate Warrior
| deanoet |
 deanoet World Chat Champion
| neo680 |
 neo680 Nova Slayer
| Loaney010 |
| Loaney010 |
| neo680 |
 neo680 Nova Slayer
| Loaney010 |
| Nufkamp |
 Nufkamp Traffic Copper
 Posted: 19:32 - 28 Aug 2007 Post subject: |
You aint been a plank and filled it with diesel have you?  |
| alun111 |
 alun111 World Chat Champion
| Loaney010 |
| Loaney010 |
| Walloper |
 Walloper Super Spammer
 Posted: 21:08 - 28 Aug 2007 Post subject: |
Flooding is one of those 'Laymen's Words' for not sure what I've/you've done to it.
It means you have over enriched the air fuel mixture going into the cylinder/s.
The bike guy was almost right in what he advised as solution.
You need to open the throttle WIDE open and kick/crank it over a few times.
This has the effect of 'Blowing' the extra fuel through the engine.
It will not run if too much fuel as there is not enough oxygen present for the fuel to ignite/burn.
After a couple of turns set the choke if fitted and start as normal.
Do not phafh with the throttle this time.
There is no such thing as 'A knack' to start an engine.
This is just the engine saying fix me or start me properly.  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| deanoet |
| Pete. |
 Pete. Super Spammer
 Posted: 23:26 - 28 Aug 2007 Post subject: |
Walloper is right, if the air/fuel mixture is richer than around 10:1, your bike won't fire and run (depends on many variables etc). Normal is around 13.5-14:1. ____________________ a.k.a 'Geri'
| Walloper |
| matty49 |
 matty49 Two Stroke Sniffer
| Loaney010 |
| alun111 |
| konsoli |
 konsoli Traffic Copper
| Cigaro |
 Cigaro World Chat Champion
| konsoli |
| gadfium |
 gadfium Trackday Trickster
 Posted: 16:21 - 29 Aug 2007 Post subject: |
| konsoli wrote: | | TheBassJunky wrote: | A petrol engine won't normally run on diesel alone as it simply will not ignite from a spark - it's not flammable enough. You can drop a lit match into a bucket of diesel and it won't burn.
It won't fuck the engine either, although it may block things up quite badly.
Your mate probably had some petrol left in the tank. |
Oh, Okay.
Well won't the diesel still combust from the piston compressing it? can't that happen?
and yer he did have some petrol in the tank, but he fought his way through all the diesel, cleaned it, filled it with petrol and I don't think he's had any failures since. Lucky. |
A petrol engine would not have enough compression to ignite the diesel/air mixture. Plus the injectors/pump would not be suitable for diesel oil (I don't even want to thing about carbs).
Diesel can damage an engine (injectors for instance). Also, it MAY damage a catalyst (sulphur content?).
If you only had a small amount of diesel in a full tank of petrol, then it would probably be OK. I wouldn't fancy a high ratio, or try it in anything more sophisticated than a ped. ____________________ Those who risk nothing, do nothing, achieve nothing, become nothing. |
| Walloper |
The last post was made 18 years, 229 days ago. Instead of replying here, would creating a new thread be more useful? |
