What's going on with my front brake?
repiV
PostPosted: 20:58 - 01 Sep 2007    Post subject: What's going on with my front brake? Reply with quote
It's quite hard to explain, but it isn't smooth or progressive. If I, for example, hold the front brake in at a particular position it feels like it's applying and releasing to a certain extent - the bike will basically jerk to a stop.
Really odd, and annoying...no idea what's causing it though. Any advice would be appreciated.
sickpup
Old Timer
PostPosted: 21:12 - 01 Sep 2007    Post subject: Reply with quote
Sounds like you have a warped disc.
Lanny
PostPosted: 21:14 - 01 Sep 2007    Post subject: Reply with quote
Sounds like you`ve got a warped disc mate Sad
Had that same feeling on my GSX - The warped disc showed up on the brake tester at MOT time Crying or Very sad
The Bloke from Stoke
Lanny
Oops
repiV
PostPosted: 21:23 - 01 Sep 2007    Post subject: Reply with quote
Oh shite. That sounds expensive. Sad
It passed its MOT a few weeks ago, nothing was mentioned about that - advisory for bent handlebars and bent clutch lever.
It was dropped in a low speed slide by the previous owner, which caused the above problems.
Are there any other problems caused by a warped disc? Is it going to cost £££'s to fix?
Lanny
PostPosted: 21:27 - 01 Sep 2007    Post subject: Reply with quote
Depends on the bike
Plenty of pattern discs around for less than OEM
Or you could risk the second hand route (beware)
repiV
PostPosted: 21:33 - 01 Sep 2007    Post subject: Reply with quote
Lanny wrote:
Depends on the bike
Since I'm mechanically inept, the phrase "getting arseraped by a garage" springs to mind... Smile
lllN30lll
PostPosted: 21:38 - 01 Sep 2007    Post subject: Reply with quote
doesn't take 10 mins to change a disc, easily done by yourself. Thumbs Up
Turbo R1
CRF450R
Timmeh
PostPosted: 10:15 - 02 Sep 2007    Post subject: Reply with quote
aye. Just don't bodge it. Tighten the bolts evenly around the disc to the correct torque and use a drop of non-permanent locking fluid on the threads to make sure it all stays put.
repiV
PostPosted: 10:34 - 02 Sep 2007    Post subject: Reply with quote
That's good to know, thanks...guess I'll go hunt for a new disc now. Smile
lllN30lll
PostPosted: 11:00 - 02 Sep 2007    Post subject: Reply with quote
when replacing the discs if you have 2 on the front it's best to replace them both at the same time, and replace your pads as well
Turbo R1
CRF450R
repiV
PostPosted: 11:13 - 02 Sep 2007    Post subject: Reply with quote
Sounds a bit more complicated....
Ah shit, I just remembered. A few weeks ago I tried to ride off and forgot I still had a disc lock attached - I wasn't really pulling away gently and the bike came crashing down. No doubt that's what fucked up the disc. Evil or Very Mad
Dalemac
PostPosted: 11:57 - 02 Sep 2007    Post subject: Reply with quote
You should get the disk lock that reminds you to take it off Very Happy
YBR125 -> GPZ500S -> SL1000
david1959
PostPosted: 22:15 - 19 Sep 2007    Post subject: disc problem Reply with quote
i was just reading the the thread here and thought i ought to say somthing.
dics run very hot so be careful if use use a loctite type product
it doesnt work at raised temperatures that you will find on a disc
from memory loctite is useless above 100 deg c
discs often have a blue tinge to them indicating the temperature
around 250 deg c
david
xs500c owner from 1978
The last post was made 19 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 79.07 Kb
