2 Stroke, Engine Rattle <--help!
darkangel
PostPosted: 17:22 - 03 Sep 2007    Post subject: 2 Stroke, Engine Rattle <--help! Reply with quote
DT125, did a top end rebuild and it ran fine with no strange noises, had to take the top end off a few times due to an overheating problem, i also took the right hand engine casing off for a new gasket, now the engine runs fine (run in and powerfull) but at certain revs there is a metallic rattling noise, it happens somewhere around idle speed (sometimes it rattles sometimes it doesn't) at 3-4k revs and just as the powervalve opens at 5.5k revs. It can also be heard when acceleration stops and revs drop.
Also i cant find where the noise is comming from, it sounds like it could be the small end bearning but i just replaced that.
The thing is before i stripped the engine down a few more times it was fine, no rattling atall, i did 40 miles on it and there were no strange noises (till the cooling system failed and i was left stranded)
If someone can tell me how i could host a sound file of it i could post it here.
Thanks
druidsam
PostPosted: 23:13 - 03 Sep 2007    Post subject: Reply with quote
i would be looking for something loose that could be vibrating at certain revs,it could even be an external component.im no expert but i would eliminate the obvious first it you haven't already done so
......................sam
trust me! I'm a druid
https://www.bikerforum.co.uk/
Jamie S
PostPosted: 00:41 - 04 Sep 2007    Post subject: Reply with quote
My TLR200 has a rattle.
Know what it is ? The kill switch, no way to stop it but its doing no harm..
Check for lose things first.
darkangel
PostPosted: 13:40 - 04 Sep 2007    Post subject: Reply with quote
Its definately comming from the engine, sounds as if something is loose and rattling around..dont think i left a spanner in there.
Think ill take it apart today, is it okay to take the right side engine casing off (holds the tranny oil and has the gears inside) and then run the bike for a few seconds to see if anything there is causing problems? would it damage the bike?
The last post was made 19 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 39.17 Kb
