| Messy |
 Messy Scooby Slapper
| iooi |
 iooi Super Spammer
 Posted: 14:02 - 03 Sep 2007 Post subject: |
Owners manual should tell you, or manufactures web site.
It can be different depending on what make of tyre you have on. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| distortion |
 distortion Nearly there...
| MarJay |
 MarJay But it's British!
 Posted: 05:33 - 04 Sep 2007 Post subject: |
Never check the tyre for the correct pressure for your vehicle. As above it's only a "maximum pressure for that tyre" Most times this will be well above what's recommended for the vehicle it's fitted to. ____________________ a.k.a 'Geri'
| distortion |
| sickpup |
 sickpup Old Timer
| feef |
 feef Energiser Bunny
 Posted: 10:03 - 04 Sep 2007 Post subject: |
| map |
 map Mr Calendar
 Posted: 14:44 - 04 Sep 2007 Post subject: |
If you're running the bike on the standard tyres (as fitted when new) then pressure should be in owners manual. As stated the psi on the tyre is nothing to do with the actual value you need to put in there.
If you're running another make of tyre then best bet is to contact the tyre company. Ok, the values in the manual will be in the right ballpark but contact the makers if you want to be sure.
It's quite surprising how much difference a few psi can make to the handling. Always the first thing to check before any (expensive) suspension/damper modifications. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
The last post was made 18 years, 207 days ago. Instead of replying here, would creating a new thread be more useful? |
