| aquaplane |
 aquaplane L Plate Warrior
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 20:49 - 04 Sep 2007 Post subject: |
if it does 40, its probably de-restricted... or are you telling porkies/speedo over reading.
if its a 10 year old 2t that hasnt had a piston change then its probably a bit fucked.
its simple to de-restrict really, its just a case of finding out what restrictions you have in the first place, if any.
if its a 4t, they cant really be restricted.
does it go 'screeeeee'
or 'brmmmmm'? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| aquaplane |
 Posted: 21:08 - 04 Sep 2007 Post subject: |
I did say it does almost 40, the speedo is in KPH and converted it says 38 MPH, about, ish.
It's deffo a 2 stroke, and it seems to do OK mixing it right too. It's only done 7000 KM, to work and back sort of thing.
The engine is all original except the new piston it had after 500 KM when the oil mixture wasn't right, that was done under warranty tho.
Brmmmm sounds a bit butch for the bike, but it's closer than screeeee, what does that tell you?
Thanks so far.
vvvv if that's the case it's not restricted, it's faster than that, or the speedo is waaaayyy off vvvv
| Damon |
 Damon World Chat Champion
| MaybeGuy |
 Posted: 21:12 - 04 Sep 2007 Post subject: |
the sound just confirms its a 2stroke.
normally you have carb restrictors, which can be restricted jets, a washer preventing the needle jet opening far enough, or an airbox filter stopping the required amout of air getting through the carbs.
an exhaust restrictor can also be an end can restriction like on the NSR or usually on peds its an extra pipe that needs to be cut off and welded over/crimped.
another type is variator restriction, this is in your belt drive assuming you dont have gears, its similar to the carb restriction but its a washer restricting how far up the gear the belt can travel. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
The last post was made 18 years, 223 days ago. Instead of replying here, would creating a new thread be more useful? |
