XP Installation problems
instigator
PostPosted: 20:35 - 04 Sep 2007    Post subject: XP Installation problems Reply with quote
I'm trying to sort my sisters PC and the following is the course of events:
PC Breaks down.
Motherboard & CPU blamed (it was an ancient 2.2ghz celeron anyway) so I throw it out and replace it with this:
https://misco.co.uk/applications/SearchTools/item-details.asp?EdpNo=278926&Sku=110886
I install it, connect everything up and boot from CD. It hung just after booting from CD, freezing on "Detecting system configurations etc". Tried it about 20 times and it never got beyond that point.
Apparently it was either the memory or the Hard Drive that was causing the issue.
So having bought this type of memory with the Motherboard, I take it back and get a replacement (same stuff as before):
https://misco.co.uk/applications/SearchTools/item-details.asp?EdpNo=236318
Now with the new memory installed (2 sticks), it still does not boot any further.
I replaced the original hard drive with a freshly formatted 250gb IDE hard drive. No change.
The system has a brand spanking new 450W ATX Power supply installed. I have tested the XP disc and it does indeed boot off correctly into the windows installation on 2 different computers.
Any ideas? If I replaced the CD-R & DVD-Rom drives it would be a whole new friggin machine!! Is it the memory? Is it the hard drive? Borked motherboard? Incorrect setting somewhere???
lllN30lll
PostPosted: 20:57 - 04 Sep 2007    Post subject: Reply with quote
try a different copy of XP
Turbo R1
CRF450R
instigator
PostPosted: 21:09 - 04 Sep 2007    Post subject: Reply with quote
But it's worked on two other computers.
I even tried burning another copy on a fresh CD. Nae luck. Boots up fine and would install fine on other machines though
T1z3R
PostPosted: 21:14 - 04 Sep 2007    Post subject: Reply with quote
swing by and pick up an optical drive. its the last resort.
duck my sick!
lllN30lll
PostPosted: 21:17 - 04 Sep 2007    Post subject: Reply with quote
put your own DVD drive in there to see if the installation starts using your drive.
Turbo R1
CRF450R
instigator
PostPosted: 22:01 - 04 Sep 2007    Post subject: Reply with quote
I put my own CD-rw drive in and still the same problem.
I go into BIOS/CMOS (?) settings and start scrolling about and it freezes yet again. It seems it is just randomly freezing on certain stages of booting up. WTF!
Anything to do with motherboard settings? CMOS Jumpers? *shrug* Running out of options here.
This machine was originally an eMachines PC with eMachines recovery discs. Tried using them but the getting the same problem, it just freezes. Would the cpu be causing this somehow?
2t-Screamer
PostPosted: 22:04 - 04 Sep 2007    Post subject: Reply with quote
cpu overheating?
visit Collective Knowledge
instigator
PostPosted: 22:07 - 04 Sep 2007    Post subject: Reply with quote
It can sometimes freeze up within 10seconds of turning it on.
Can the CPU overheat in that amount of time?
Funnily enough, when I turn it on after leaving it for a while, it does get as far as it can before freezing where repeated attempts straight after don't get as far.
The Heatsink supplied came with thermal paste already on it, perhaps one should dig out the old artic silver. Evil or Very Mad
2t-Screamer
PostPosted: 22:09 - 04 Sep 2007    Post subject: Reply with quote
a cpu can overheat almost instantly
2t-Screamer
PostPosted: 22:10 - 04 Sep 2007    Post subject: Reply with quote
could also be gfx card overheating?
Philious
PostPosted: 22:26 - 04 Sep 2007    Post subject: Reply with quote
What graphics card are you using, i found on my old system ages ago when i first got xp if i had my nvidia graphics card in the computer it would just freeze up
i swiched this for a cheapo 4mb agp card and lo and behold it didnt freeze, yet windows ran fine after installation when i reinserted the nvidia card.
just from my experience
hth
Previously; Honda XR125 - Yamaha DT125r - Aprilia Rs125 - Suzuki GS500e, Currently; Kawasaki ZX6R + ZX10R
Theory : Passed 28/7/09 Module 1: Passed 21/09/09 Module 2: Passed 23/09/09
JonT
PostPosted: 22:29 - 04 Sep 2007    Post subject: Reply with quote
I would put my money on bad ram timings or too low a ram voltage.
Newer low latency ram sticks use a higher voltage then what the bios may default to.
I would start however my turning on 2T command, and lowering (which means increasing the number!) the CAS latency in the bios. Then try ramping the ram voltage up (again in bios) in the smallest possible increments.
The last post was made 18 years, 349 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.15 - MySQL Queries: 13 - Page Size: 71.78 Kb
