FZR600 '89 Wobble?
Jenks
PostPosted: 17:58 - 06 Sep 2007    Post subject: FZR600 '89 Wobble? Reply with quote
Hey all,
Right bit of a weird one with my FZR.
Basically i was out on the private runway, and i took her upto 100.
once you reach 100 ++ It starts wobbeling / shakeing... not tank slapper type, just kinda of swaying, And it gets worse and worse untill it nearly does tank slap..
What could cause this!?
1978 MZ TS 250 1 Supa 5
1992 yamaha fzr1000 exup
1998 aprilia af1 sintesi
Timmeh
PostPosted: 19:44 - 06 Sep 2007    Post subject: Reply with quote
worn swingarm pivot, wheel bearings or steering head would cause what you describe.
Or it could be something really simple like the back wheel not being lined up properly.
bish777
PostPosted: 19:58 - 06 Sep 2007    Post subject: Reply with quote
Check tyre pressures and their condition, check your steering stem nut is torqued to the correct spec, all the spindles are done up tightly then start checking all your various bearings.
GSXR1100J
Jenks
PostPosted: 20:59 - 06 Sep 2007    Post subject: Reply with quote
Right, thanks for the help i will get onto checking these.
As far as i know the bearings are fine, as it was only just moted (July - and wobbeled then)
Advisory was that the headrace bearings were a little tight - but this was because of not being use.
How do i check alignment?
Timmeh
PostPosted: 21:05 - 06 Sep 2007    Post subject: Reply with quote
A way to check wheel alignment is to use a really long straight rule. Line it up with the back wheel and see if the front is parallel. You can also use a piece of string tied to the back wheel if you like.
PostPosted: 23:03 - 06 Sep 2007    Post subject: Reply with quote
You haven't dropped the yolks down the forks have you?
TUG
PostPosted: 23:54 - 06 Sep 2007    Post subject: Reply with quote
i had a slight wobble due to the bar ends not being in evenly, check that too, it makes a difference.
Haz ER-5, innit!
Jenks
PostPosted: 14:16 - 07 Sep 2007    Post subject: Reply with quote
nope yolks are the same, Ill check the bar ends right now too see them!
anything else?
Jenks
PostPosted: 15:42 - 07 Sep 2007    Post subject: Reply with quote
tyres are bt45s i think, I know headrace were an advisory on the mot - Because they were a little tight (Was stored)
Jenks
PostPosted: 16:34 - 07 Sep 2007    Post subject: Reply with quote
nope, only just really got it!
bish777
PostPosted: 16:42 - 07 Sep 2007    Post subject: Reply with quote
incorrectly torqued steering nut will cause weaving, get it torqued up properly. My FJ1200 was horrid over 100mp until i got the steering stem nut torqued properly.
GSXR1100J
PostPosted: 17:44 - 07 Sep 2007    Post subject: Reply with quote
Don't think the BT45 is available in an appropriate size for the FZR600. Presume you have used a 150/70 tyre, which will have lifted the back end up 15mm or so, an quickened the steering.
Jenks
PostPosted: 22:27 - 07 Sep 2007    Post subject: Reply with quote
not sure then! bike isnt stored here, its at my mums!!
its a 140/60/zr18
PostPosted: 00:23 - 08 Sep 2007    Post subject: Reply with quote
Jenks wrote:
its a 140/60/zr18
If it is a zr then it isn't a BT45 on there (the r is for radial and the BT45 is a cross ply tyre).
TUG
PostPosted: 16:48 - 08 Sep 2007    Post subject: Reply with quote
sorry to hear about that, i tell everyone who owns fzrs to keep to the stated tyres, even on a thin 140 i got my knee down, my friend has an over size on his cbr, best get him to check this post
Haz ER-5, innit!
Jenks
PostPosted: 19:03 - 09 Sep 2007    Post subject: Reply with quote
Tyres = Dunlop Sportmax Radial.
Rear = 140/60/zr/18
front = 110/70/zr/17
When i was out today i tested not holding on so hard, it it DID calm it ALOT!!!!!
TUG
PostPosted: 19:06 - 09 Sep 2007    Post subject: Reply with quote
lol, so you where wobbling on it?
Haz ER-5, innit!
Jenks
PostPosted: 19:19 - 09 Sep 2007    Post subject: Reply with quote
the wobble wasnt as potent, but it was still there, But hardly noticeable!
PostPosted: 19:20 - 09 Sep 2007    Post subject: Reply with quote
They should be fine, although they are not particularly good tyres (I know, I have them, although with a 150/60 rear, on my FZR600) and will be old tyres.
To be honest I have not found the FZR nervous at all (and mine has done over 50K now, on the original shock as far as I know). Pretty stable as stock.
I would say go round having a good check over everything. Steering head bearings, wheel bearings, fork seals / bushes (and if you find a supplier for both top and bottom bushes then let me know!), etc.
Jenks
PostPosted: 19:28 - 09 Sep 2007    Post subject: Reply with quote
would it be best to get a 4" rim?
The last post was made 19 years, 42 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 128.03 Kb
