Headlight problems
Dalemac
PostPosted: 20:41 - 07 Sep 2007    Post subject: Headlight problems Reply with quote
Hey all, got a ybr125 Confused
my dipped headlight (and sidelight) went the other night so today i replaced the bulbs, the sidelight is all and dandy but the dipped beam is not working, but fluck to high beam and it works.
I took the headlight apart again and checked the connection and all the wires etc and it seems fine, tried again to no avail.
I need the bike tomorrow as im taking two days intensive lessons before my test on the 17th.
Any ideas?
thanks in advance,
Dale
YBR125 -> GPZ500S -> SL1000
MattEMulsion
PostPosted: 21:51 - 07 Sep 2007    Post subject: Reply with quote
Either its a duff bulb that you have fitted or maybe a fuse has blown but that is unlikely given that the other lights work. Could be a wiring problem.
Yamaha YZF-R6
Dalemac
PostPosted: 21:54 - 07 Sep 2007    Post subject: Reply with quote
Dam.
Just when i need my bike to be roadworthy.
Looks like im up at umpteen oclock in the morning to try and source another bulb and/or a multimeter.
MattEMulsion
PostPosted: 21:58 - 07 Sep 2007    Post subject: Reply with quote
Take the bulb out and if your eyesight is decent you should be able to see if the filament is broken or intact. A gentle flick on the side of the bulb often helps you see if the filament has a break.
Other than that you are sure you are looking at the right bulb aren't you. Stupid question I know, but stranger things have happened.
Yamaha YZF-R6
Dalemac
PostPosted: 22:31 - 07 Sep 2007    Post subject: Reply with quote
ive got good eyesight and when i checked the bulb looked fine and fully intact to me.
yep im sure ive got the right bulb, there is two in my headlight, one sidelight (comes on automatically when the key is turned) and the main bulb which has a high and dipped filament, which comes on when the bike is running. usually takes a couple of seconds for the high/ dipped to come on.
it has been suggested on my local forum the problem is either with the bulb, the switch or the wiring from the switch to the headlight is not working, of corse i cant tell as i dont have a multimeter Sad
/stress mode off
The last post was made 19 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.42 Sec - Server Load: 4.94 - MySQL Queries: 13 - Page Size: 43.01 Kb
