Bros clutch
mr jamez
PostPosted: 18:53 - 08 Sep 2007    Post subject: Bros clutch Reply with quote
Hello Laughing
I'm a tad confused. I've got the clutch on, I did everything to the manual. I put the cover on, pulled the lever and its solid as soon as the lifter piece touches the bearing. Looking at it the lifter plate is up tight against the mainshaft nut.
Do you tighten the bolts on the pressure plate just enough so that it can push the plates together? All it states is to do them up to a certain torque, but my torque wrench doesn't go that low.
When I did the clutch on my NSR I just tightened up the pressure plate and that was it.
Question
sickpup
Old Timer
PostPosted: 05:58 - 09 Sep 2007    Post subject: Reply with quote
Not totally sure what you mean so I will run through a few problems with the Bros clutch.
You often get sold NTV600/650 springs for these, they fit physically but are coil bound i.e. completely compressed when fitted so the clutch cannot disengage.
If the plates are too thick the stack height is too high so the springs are coil bound so again it can't disengage.
If the lever doesn't move its one of the above.
mr jamez
PostPosted: 18:25 - 09 Sep 2007    Post subject: Reply with quote
It was the springs, I whacked the old ones in and it rode fine all day Thumbs Up
TUG
PostPosted: 18:46 - 09 Sep 2007    Post subject: Reply with quote
??? shouldnt you use the new ones? its solid as a rock? or just really really stiff? did you soak the clutch plates in oil before installin em?
Haz ER-5, innit!
sickpup
Old Timer
PostPosted: 20:05 - 09 Sep 2007    Post subject: Reply with quote
It was probably solid as a rock if it had the wrong springs. Parts people seem to think that as the engine is available in many forms all the parts are interchangeable, they're not.
Sickpup does a little Dance!
TUG
PostPosted: 20:41 - 09 Sep 2007    Post subject: Reply with quote
man your on fire tonite, dance away Smile Thumbs Up
Karma
Haz ER-5, innit!
The last post was made 19 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 47.59 Kb
