| Toxic |
 Toxic L Plate Warrior
 Posted: 16:55 - 02 Sep 2007 Post subject: RS 125 Help Needed |
hi guys hope some one can help? got 1999 rs 125 bought it a couple of weeks ago, it is ment to be the full power, when i hit 8000rpms she pulls like mad, but i can't get passed 80, i've read on the net i should be going pass this but i'm at a lost on this so any ideas? thats the first prob
This is the second prob, was riding to work last week, doing about 70 when she seized, felt like when she runs out of fuel, dropped the clucth and stopped. Tried to restart but just coughed and splutted. striped the engine down and piston is undamaged and still moving freely and is oiled. But before i striped it i put it second and would not turn, when i striped it i pushed the piston and it slid down, so i put it in second and it moved back up. Found the powervalve was upside down and corrected it and cleaned, also i found that the cable had snapped, head gasket was burnt on one side.
So what happened??? Any help on any of these would be greatly appeciated |
| Kickstart |
 Kickstart The Oracle
 Posted: 23:37 - 02 Sep 2007 Post subject: |
They should easily manage more than 80 derestricted, but they are also geared for about 10mph per 1000rpm, so 80mph is around 8000rpm, just before the power valve opens when there is a bit of a delay in the power delivery. Quite easy for it not to pull through this if you just sit in top and hope to accelerate.
Not sure about the seizing. But the RS doesn't have a head gasket as such, just a couple of large rubber O rings.
| Im-a-Ridah |
 Im-a-Ridah World Chat Champion
 Posted: 00:17 - 03 Sep 2007 Post subject: Re: RS 125 Help Needed |
| Toxic wrote: | hi guys hope some one can help? got 1999 rs 125 bought it a couple of weeks ago, it is ment to be the full power, when i hit 8000rpms she pulls like mad, but i can't get passed 80, i've read on the net i should be going pass this but i'm at a lost on this so any ideas? thats the first prob
I'd guess it just clipped the powervalve, if the piston and barrel are undamaged you've just been lucky! As Kickstart says, it doesn't have a head gasket it has a rubber o ring, so I'm guessing your thinking of the base gaskets?
As for why it's not getting past 80mph, could be several reasons, such as you not having it jetted correctly or it could have the mixture messed up with too much oil or it could have low compression (which could be caused by many things such as worn rings or seals ect). Most likely however, I'd say your speed is being hampered by your having the powervalve the wrong way up. |
| Toxic |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 23:28 - 17 Sep 2007 Post subject: |
electrical timing.
basically, sparking at the wrong time. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Toxic |
| Kickstart |
| Toxic |
| Kickstart |
 Posted: 22:07 - 18 Sep 2007 Post subject: |
Main bearingss normally whine when they have gone. Also tend to take the seals out rapidly which is likely to result in a high idle speed which you cannot adjust down (ignition side) or using gearbox oil (clutch side). Can feel for play in the ignition side one by holding the flywheel and trying to feel for up / down play.
Woodruff key shearing off can happen. Check the ignition timing. Woodruff key is there to locate the flywheel on the crank. Easy to replace and cost peanuts.
| Toxic |
| Kickstart |
| Toxic |
The last post was made 18 years, 327 days ago. Instead of replying here, would creating a new thread be more useful? |
