oil/air cooled motors, bandit for example
Keir
PostPosted: 09:37 - 18 Sep 2007    Post subject: oil/air cooled motors, bandit for example Reply with quote
How do they keep cool in heavy traffic etc? Unlike wc bikes that have a fan etc.
Can they overheat? should different oils be used as its for cooling aswell?
discuss...
Current : '08 Yamaha FZ1s
PostPosted: 09:39 - 18 Sep 2007    Post subject: Re: oil/air cooled motors, bandit for example Reply with quote
They just overheat don't they?
Unless they have a fan behind the oiler cooler, A/C bikes simply overheat then cut out.
doggone
PostPosted: 10:01 - 18 Sep 2007    Post subject: Reply with quote
Probably just have more spare capacity.?
Rode my bandit1200 in european cities at almost 40C with no ill effects.
Since bikes are pretty much the same design to be used worldwide we shouldn't have them get too hot very often in the UK.
Keir
PostPosted: 10:30 - 18 Sep 2007    Post subject: Reply with quote
but what about when they are just sitting there idling, surely its just going to get hotter and hotter until it melts?
I'll explain my reasoning... i was sitting in gridlock in central london today and it was getting very hot. it occured to me that its just going to get hotter and hotter and theres nothing i can do about it. my bandit has no temp gauge so i couldnt really tell how hot it was. surely it cant be good for the bike.
Jamie S
PostPosted: 10:45 - 18 Sep 2007    Post subject: Reply with quote
Every Sunday my Air cooled honda TLR200 Trials bike has the engine running for around 4 to 5 hours non stop, Never going more than about 10 mph and often just sitting waiting to do the sections.
It never over heats and is fine , don't worry about it mate.
bish777
PostPosted: 11:46 - 18 Sep 2007    Post subject: Reply with quote
Oilcooled bikes (PROPER GSXRs, B6/12, GSXF) use an effective oil jet system and a large amount of oil so therefore actually stay pretty cool for an extended time at standstill. Certainly not enough to worry about a bit of traffic. They dont need much windspeed to get effective colling from the radiator.
Aircooled motors vary, My FJ1200 didnt like heavy traffic and would overheat fairly quickly. However most other aircooled bikes seem to be more or less unaffected.
GSXR1100J
Keir
PostPosted: 11:48 - 18 Sep 2007    Post subject: Reply with quote
ok i wont worry about it, now im interested how it does cool the engine.
Is it just the oil circulates and where theres a fair bit in there it warms while in the engine then cools in the sump until circulated again?
bish777
PostPosted: 11:55 - 18 Sep 2007    Post subject: Reply with quote
The GSXR750/1100 motor (which is also in the Bandits, GSXFs and a few others) hold alot of oil, which is circulated around the motor under fairly high pressure. The cylinder head gets a high pressure supply where the oil is sprayed all over the top end, aiding head cooling and lubrication. There are also oil sprays that spray the bottom of the pistons keeping cylinder tempratures low.
I dont know about the B6 but the GSXRs have a large radiator that the oil passes through-this provides the majority of the cooling for the oil, the fins on the motor are more decoration really.
Suzuki designed this system for the original GSXR 750 as at the time watercooling would have made the engine heavier and larger. Also it allows you to keep the engine light-compare a GSXR1100 engine to the old aircooled katana/GSX engine which is HUGE by comparison.
GSXR1100J
doggone
PostPosted: 12:51 - 18 Sep 2007    Post subject: Reply with quote
Just a thought, if you think it's getting hotter than you noticed before, it may not be circulating the oil so well.
Filter and oil change might be overdue?
PostPosted: 12:54 - 18 Sep 2007    Post subject: Reply with quote
If the filter gets blocked with rubbish then it should bypass the filter so having no effect on the oil flow.
If a sign of anything it would be of a worn oil pump.
SonicTheHedge...
You've also got to remember that the hotter the bike gets the faster the bike will transfer heat away, so whilst it heats up quickly at standstill it'll level out (unless you're sat there with the throttle pinned, of course... Rolling Eyes ).
The B6 has a nice oil cooler bolted to the front to chuck away a decent chunk of heat, after all.
Previous: '00 G2 Bandit 600 Naked. Now: '08 BMW GS Adventure.
iooi
PostPosted: 21:19 - 18 Sep 2007    Post subject: Reply with quote
Keir_K3 wrote:
my bandit has no temp gauge so i couldnt really tell how hot it was. .
One less thing to worry about....
One reason i love air cooled bikes, you don't have that worry of watching the needle rising into the red and thinking "Oh Fook"
The larger surface area on the cylinders does a very good job of disapating the heat. The fact you can feel it rising up means they are doing their job.
Start worrying when on a hot day in traffic when you can't feel the heat....
Nath
PostPosted: 22:15 - 18 Sep 2007    Post subject: Reply with quote
My XS750 is aircooled and doesn't like running stationary at all. Had it get so hot that when I stalled it I could barely turn the engine over via the kickstarter. The later 850cc model had a oilcooler, I fitted this to my 750 and it deals with slow speeds much better now. Think the extra oil capacity alone makes a massive difference.
My aircooled cb550 is pretty resiliant, but I have had it near to siezing a few times (all the oil on the outside of the engine starts burning off, and it gets very hard to kick over).
On both bikes, if I get caught in traffic I will turn the motors off whenever I get stopped at lights. On a motorway run on the xs750 outfit last month, the A1(M) was totally chocka and I had to stop on the hard shaulder several times to wait till the traffic started moving fast enough to warrant getting back in it.
Hard livin', hard luck.
Noxious89123
PostPosted: 22:33 - 18 Sep 2007    Post subject: Reply with quote
Was out riding quite "spiritedly" then had to slow down and stop in traffin stow...
Temp gauge quite steadily upto about 3/4 on the gauge.. usually sits just under the 1/4 position.... Needless to say i was shitting bricks that something was wrong with the bike, but i could see no damage or water leaks...
As soon as i got out of the traffic and got her moving again she cooled back down to normal in the space of about 30 seconds!
virus
PostPosted: 19:59 - 19 Sep 2007    Post subject: Reply with quote
the z overheated and heat siezed the day i got it,
bastard throwasiki
John
own: 81 xs1100g...
PostPosted: 23:38 - 19 Sep 2007    Post subject: Reply with quote
Motor manufacturing clearances on liquid cooled bikes are much closer than on air cooled bikes.
The larger clearances allow for the much the larger coefficients of expansion of the components due to to the larger temperature range on an air cooled bike.
This was very noticable on early Yam and KwaK 2 strokes that used to rattle noticably more when cold than when at normal temperature.
It also the reason why liquid cooled bike usually last longer with less major engine maintenance than air cooled bikes.
Low tuned large capacity bikes like the FJ1200 being an exception before you all slaughter me Rolling Eyes
bish777
PostPosted: 23:34 - 20 Sep 2007    Post subject: Reply with quote
Well till one afternoon of dodgy thermostat warps the head, and the thing drops valves......
GSXR1100J
bigbike-r
PostPosted: 11:32 - 21 Sep 2007    Post subject: Reply with quote
the oil cooled motors
in this pic you can see the oil - highlighted orange for obviouse reasons... the engine holds a good ammount of oil and serves 2 purpouses 1- to lubricate the engine and 2 to cool down the oil is picked up from the sump of the motor and up behind the ricker cover where it goes down passages and is released through the top of the head and back down through the oil cooler youll notice your motor has the fins on too whereas the watercooleds dont this is to aid in the air cooling heat away from the engine i wouldnt worry about your motor overheating its never gonna get that hot - though it is possible to add a secondry oil cooler as was run on the yoshimura tornado wich i am in the process of doing on my gsxr - at the back of the motor between the catbs youll see a Y shaped oil line connecting to the rocker cover ... yoshimura make the fittings for this but they can be fabricated using the origionals. with the new fittings , one hose goes from that bottom connection to one side of another cooler and the 2 from the rocker cover are joined by a 3 way connector leading them into 1 seperate pipe wich attatches to the other side of the cooler... they can be mounted in the nose cone or if your using it on the road or need a light in there most people mount them under the existing cooler
Keir
PostPosted: 12:07 - 21 Sep 2007    Post subject: Reply with quote
very helpful, thanks
The last post was made 19 years, 16 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 110.67 Kb
