JOLTING/SHUDDERING/JUMPING
lee8040
PostPosted: 09:25 - 18 Sep 2007    Post subject: JOLTING/SHUDDERING/JUMPING Reply with quote
bike = kymco zing 125
when i hold the accelerator in the same poisition while riding, proberbly around 30mph it will judder and jump forward and backwards. it doesnt do it when the accelerator is let go or when i accelerate. can anyone think of a cause?
PostPosted: 22:00 - 18 Sep 2007    Post subject: Reply with quote
sounds like the chain is loose.or at least in that general area.
not 100% though but its a good place to start.
dave
DRZ-400sm
Thom_NSR
PostPosted: 23:50 - 18 Sep 2007    Post subject: Re: JOLTING/SHUDDERING/JUMPING Reply with quote
Does the problem occur no matter what the revs are? Maybe you just need to shift down a gear Wink Thumbs Up
lee8040
PostPosted: 11:27 - 19 Sep 2007    Post subject: Reply with quote
yes when im mid range it happens to so if i downshift ill be over revving in a lower gear.
Keir
PostPosted: 11:56 - 19 Sep 2007    Post subject: Reply with quote
petrol full?
Chain and sprockets ok and adjusted properly?
Current : '08 Yamaha FZ1s
TUG
PostPosted: 13:32 - 19 Sep 2007    Post subject: Reply with quote
set your fuel/air mixture propperly and it will dissapear
Haz ER-5, innit!
lee8040
PostPosted: 13:40 - 19 Sep 2007    Post subject: Reply with quote
ive never touched it its ran fine for months now its strated to go funny
TUG
PostPosted: 13:41 - 19 Sep 2007    Post subject: Reply with quote
hmm dunno then, whats changed?
Haz ER-5, innit!
Spoon261
PostPosted: 15:33 - 19 Sep 2007    Post subject: Reply with quote
The weather has turned colder.
When the outside air changes temperature, it changes your air to fuel mixture if you have a carb (not fuel injected).
If the air to fuel mixture is set up correctly it can manage with normal changes in air temperature.
But if its not set up correctly, could give the fault described.
A website all about how to set it up is below
https://hondanighthawks.net/carb14.htm
Honda CG125 Website https://hondacg125.awardspace.com/
Honda CBF125, CBR125 & Yamaha YBR125 Website https://125ccbikeclub.awardspace.co.uk/
I have left bikechat forums, I do not read pm (Private Message)
lee8040
PostPosted: 08:33 - 21 Sep 2007    Post subject: Reply with quote
after giving it some thought it seems very similar to the problem i had on my sccoter and that was caused by a damaged ht lead which eventually snapped completley.
im going to replace the ht lead and spark plug this weekend and pray it works
Spoon261
PostPosted: 11:51 - 21 Sep 2007    Post subject: Reply with quote
There are loads of possibilities for the fault you described.
The manufacturer / country (quality control) its made in also brings up loads of extra potential problems.
My Honda CG125 website could be some use, I am not sure if your engine is a clone of the Honda CG125, but even if its not, all the non valve clearance / spark plug information should be of use.
The following list is the basics you should check.
Air Filter clogged?
Spark Plug condition and colour (tells you how your engine is running).
https://www.verrill.com/moto/sellingguide/sparkplugs/plugcolorchart.htm
Valve Clearance
Its also possible you have got a fuel starvation / blockage some ware.
It would be a good idea to try a better quality petrol which has extra inbuilt cleaners in, see my Petrol section in my General webpage on my website.
Also see How to stop your engine clogging up on that page.
For the hell of it, check your spark plug connections, battery etc.
The last post was made 18 years, 356 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 67.41 Kb
