NSR - Out of luck :(
spike_Alike
PostPosted: 14:28 - 19 Sep 2007    Post subject: NSR - Out of luck :( Reply with quote
Bah, just been out on the NSR and it's died on my 10 mins into the ride.
Going down the road, hit the brakes to slow down for the granny infront (was doing ~70), and a couple of mins later the bikes spluttering and struggling. I pulled over, and she's died.
I managed to start her up again, try and ride home. It's ok for 2 mins and then it splutters and dies again. Pull over, try again. Eventually starts (with some difficulty this time) and make it home.
Any ideas? It's certainly not petrol, thats the first thing I checked.
Hope its nothing major because I just shelled out £280 to get it through the MOT and I'm all out of cash. But my gut feeling is that i've killed it this time.
Rolling Eyes
In short - Bike dies. Will start again with choke but not without. Dies again. Petrol not empty.
Bandit 600
NSR Mick
PostPosted: 14:30 - 19 Sep 2007    Post subject: Reply with quote
Has it got oil?
spike_Alike
PostPosted: 14:33 - 19 Sep 2007    Post subject: Reply with quote
Shouldn't be empty, unless the warning light has broke. To be honest I wouldn't be suprised if thats the case though, my first though was its out of oil.
Checking now as we speak, cheers.
Bandit 600
spike_Alike
PostPosted: 14:37 - 19 Sep 2007    Post subject: Reply with quote
Hmm, there is certainly some oil left that I can see, not tonnes but it should be enough to be honest.
Bandit 600
NSR Mick
PostPosted: 14:55 - 19 Sep 2007    Post subject: Reply with quote
What mileage has it done and when did it last have a rebuild?
spike_Alike
PostPosted: 14:58 - 19 Sep 2007    Post subject: Reply with quote
A jot under 6000, I can only assume no rebuild.
Also, it's still restricted, if thats of any use. So it's not really been abused (by me at least).
Bandit 600
NSR Mick
PostPosted: 15:02 - 19 Sep 2007    Post subject: Reply with quote
Shouldnt need one yet, I'd take the exhaust off and take a quick look at the piston if you can.
spike_Alike
PostPosted: 15:06 - 19 Sep 2007    Post subject: Reply with quote
I'll see if I can get someone who knows what they are doing to have a look at it, check the pistons ect.
Just tried it again and it's started fine, although I don't wanna give it a blast to test it incase I cause more damage.
Don't suppose it could have overheated or something? The gauge was telling me temp was normal, and I wasn't out for long however.
Bandit 600
alains
PostPosted: 17:56 - 19 Sep 2007    Post subject: Reply with quote
as always give a good cleaning at tank (tap) , carb & air foam filter , then fit a new plug (BR9EIX because BR9ECS are bull shit) set needle on the 2nd notch from top , pilot screw at 2 1/2 turns out , idle at 1500 rpm
TUG
PostPosted: 00:18 - 20 Sep 2007    Post subject: Reply with quote
how comeyou know so much on nsrs, did you race them or something? just wondering. Embarassed
Haz ER-5, innit!
alains
PostPosted: 07:58 - 20 Sep 2007    Post subject: Reply with quote
i never race but my tactic is : never pilot a bike you dont know , at least have the docs and read and learn
Nixon
PostPosted: 10:12 - 20 Sep 2007    Post subject: Reply with quote
i know this may seem a really obvious but may be worth double checking that your not running on the reserve tank
ive done this numerous times, Embarassed especialy after refueling and forgeting to switch back to main
and you sure its warmed up enougth? and not running on the choke?
i know they seem silly things but are easily forgoten about.
Polo
PostPosted: 10:23 - 20 Sep 2007    Post subject: Reply with quote
Check the fuel line hasnt kinked around or under the air box causing fuel starvation.
Happened to me and would cut out at high speed, wait a few mo's and it starts again only to repeat when travelling at speed again.
My mum smells your fingers
spike_Alike
PostPosted: 12:38 - 20 Sep 2007    Post subject: Reply with quote
Thanks for all the suggestions guys, seems like I've got some exploring to do to get to the root of this.
I certainly wasn't running on choke, after petrol, thats the next thing I checked.
Bandit 600
djrichieb
PostPosted: 12:43 - 20 Sep 2007    Post subject: Reply with quote
Took the words out of my mouth! i jammed mine after had the bike stripped down and put it back together.
Rides: Honda CB400 SF (ART can) - Citroen Saxo 1.1i SX
The last post was made 19 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 83.99 Kb
