Brake bleeding problem.
Reppyboyo
PostPosted: 16:30 - 20 Sep 2007    Post subject: Brake bleeding problem. Reply with quote
Hi,
Im trying to bleed my brakes, everything is attached and nipple is closed.
Ive added clean fluid to my master cylinder, but its not going anywhere.
No matter how fast or slow I pump the fluid is not going anywhere.
Why would this be?
Thanks for any help.
TUG
PostPosted: 16:32 - 20 Sep 2007    Post subject: Reply with quote
lol mate, you need a pipe running off the nipple into a tub or jar, you hold the lever in or down, undo the nipple, then tighten it, let the lever go and repeat until you see fluid with no air bubbles in Wink Thumbs Up
Haz ER-5, innit!
Reppyboyo
PostPosted: 17:18 - 20 Sep 2007    Post subject: Reply with quote
Cheers, this is taking ages.
Still no pressure after 3 refills from the lower mark.
fun. Razz
Reppyboyo
PostPosted: 17:30 - 20 Sep 2007    Post subject: Reply with quote
It is on a paddock stand yes.
Ill try tapping the caliper.
I dont think there is a bleed nipple near the res.
puremagic72
PostPosted: 17:55 - 20 Sep 2007    Post subject: Reply with quote
Suck it up damn you, just suck it up!!!!!
Best way,
Baz. Thumbs Up Thumbs Up
Make; cbr929cc blade Year; 2001
Gsxr 750 2000, alstare Corona, Current bike 1999 R6
(1) Kids in the back seat cause accidents; accidents in the back seat cause kids.
TUG
PostPosted: 18:02 - 20 Sep 2007    Post subject: Reply with quote
tapping the lines an caliper will move the bubbles up as air rises, pump the pedal like stated until pressure is felt, leave for a few hours then bleed again whilst filling, if theres still a lack of pressure then i suggest seeing if the caliper is seized?
Haz ER-5, innit!
Reppyboyo
PostPosted: 18:17 - 20 Sep 2007    Post subject: Reply with quote
Pumping it seems to have done the job. My hand hurts now. Shocked
Both the calipers were bled and I couldent see any bubbles, no pressure.
Pumped it as you suggested and now its very very firm.
Until I cracked the nipple that is but now theres just very fine bubbles coming out.
TUG
PostPosted: 18:21 - 20 Sep 2007    Post subject: Reply with quote
thats because the pads whert in contact with the pistons. Thumbs Up
Haz ER-5, innit!
Reppyboyo
PostPosted: 18:34 - 20 Sep 2007    Post subject: Reply with quote
Indeedy.
Bled both calipers again and no bubbles.
Pumped the lever again and its very firm once again.
Thanks for the help all!
I doubt I`ll be rideing tonight, bar a slow speed brake test on my drive, should I zip tie to lever down overnight or not bother?
Syx
PostPosted: 13:04 - 21 Sep 2007    Post subject: Reply with quote
I'm not quite sure how that results in small air bubbles... could you explain? Last time I bled my brakes I had the same thing but didn't know why.
TUG
PostPosted: 15:24 - 21 Sep 2007    Post subject: Reply with quote
after bleeding, the pistons in the caliper would of returned slightly, so when you pump the brake, the pistons touch the pads again.
Haz ER-5, innit!
Syx
PostPosted: 16:19 - 21 Sep 2007    Post subject: Reply with quote
Okay, that makes sense. So does that mean if the pistons stay in contact with the pads, air gets trapped in there - and that's the source of the bubbles?
TUG
PostPosted: 16:22 - 21 Sep 2007    Post subject: Reply with quote
no, air gets in when you undo the bleed nipple, or the banjo bolt at either end of the brake line. if you change your brake pads by just pushing the pistons in and putting the new pads in then all you have to do is pump the pedal to get the pistons back in contact with the pads. you understand now? i didnt understand it that well either till i did it myself.
Haz ER-5, innit!
PostPosted: 16:23 - 21 Sep 2007    Post subject: Reply with quote
No, you might get spongy brakes when you first apply them until it has taken up the slack but it should not allow air in.
Syx
PostPosted: 16:30 - 21 Sep 2007    Post subject: Reply with quote
Ah right I see - I've misunderstood a little here.
I've changed my pads before and knew all about having to pump the lever first, but I thought your original quote of "thats because the pads whert in contact with the pistons." referred to the fact that he said "now theres just very fine bubbles coming out".
It's all clear now!
TUG
PostPosted: 16:41 - 21 Sep 2007    Post subject: Reply with quote
sorry if i confused you a bit, glad your clear now though Very Happy Thumbs Up
Haz ER-5, innit!
The last post was made 18 years, 356 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 86.29 Kb
