Top end increase
 Topic moved: from General Bike Chat to The Workshop by G (22 Sep 2007 - 10:13)
chrisgsxr
PostPosted: 23:49 - 20 Sep 2007    Post subject: Top end increase Reply with quote
Hi every 1 ... Has any body any idea how to increase my cbr 600's top end speed?
Its good for 120 but sometimes thats just not enough lol
Any suggestions would be great Very Happy
alpine
PostPosted: 23:58 - 20 Sep 2007    Post subject: Reply with quote
Only 120mph? I thought they could do more..
Would also help if you listed out any mods you have done so far? Thumbs Up
Current bike - FMX650.
Dischord
PostPosted: 00:11 - 21 Sep 2007    Post subject: Reply with quote
120MPH to be fair is pure shit, it must have been down geared or the engine is nackered. Check the sprockets and then go up a tooth on the front and down 3-4 on the back...or you could go up 2 on the front and down 6 on the back etc depends what you want.
2012 KTM EXC 250
bish777
PostPosted: 02:09 - 21 Sep 2007    Post subject: Reply with quote
aye that is low.
Is it revving out in top?
I'd think that a CBR600 should nudge 140+ even the earliest models.
GSXR1100J
lilredmachine
PostPosted: 08:36 - 21 Sep 2007    Post subject: Reply with quote
Sounds like it's restricted? How old was the owner before you?
TUBZ69
PostPosted: 12:57 - 21 Sep 2007    Post subject: Reply with quote
agreed , sounds like its bin down geared to me matey, check the teeth numbers on front an rear sprockets with the standard amount when new.
those who risk nothing, become nothing, achieve nothing....
c90 rvf 400, vfr 400, gpz 500, Gsxr 750, R1, Zx6r....
PostPosted: 13:14 - 21 Sep 2007    Post subject: Reply with quote
120mph seems a bit high for 33hp restricted, even if used to own a mito! Razz
Unless it's quite downgeared, I reckon it's more likely it's just not running right.
If it was me, I'd clean out the carbs, clean the air filter and check the exhaust first.
Then maybe stick it on a dyno if it's still not doing great.
Mr Nice Guy
PostPosted: 13:35 - 21 Sep 2007    Post subject: Reply with quote
Couldnt it be a Jap import? Aren't the bikes limited to 112 like the cars?
Suzuki GSX-R750K4 ~ Mivv GP
PostPosted: 16:57 - 21 Sep 2007    Post subject: Reply with quote
Only 400cc or less were i think. That's gone now in Japan though.
chrisgsxr
PostPosted: 23:15 - 21 Sep 2007    Post subject: Reply with quote
I have no idea how to change the gearing of it maybe thats a job for the garage ?? .. its proper rapid all through the gears so no way is it restricted.
Maybe a dyno run is the answer ?
chrisgsxr
PostPosted: 23:16 - 21 Sep 2007    Post subject: Reply with quote
And it is deffo a UK bike not an import
bish777
PostPosted: 23:17 - 21 Sep 2007    Post subject: Reply with quote
you can change the gearing easily with a fairly basic toolkit.
A good start would be to buy a standard chain and sprocket set.
GSXR1100J
PostPosted: 23:18 - 21 Sep 2007    Post subject: Reply with quote
At 120mph are you at the redline in top gear?
If you are, it's been seriously down geared.
It's not too hard a job to change sprockets yourself, but the front one can be a bit of hassle.
mrlee1974
PostPosted: 23:46 - 21 Sep 2007    Post subject: Reply with quote
Ive been 142mph on the early cbr600,that was 2up aswell so it does sound a little restricted.
chrisgsxr
PostPosted: 00:57 - 22 Sep 2007    Post subject: Reply with quote
Thing is .... and dont shout at me !!! it isnt at top revs at 120 lol its just that i dont think it wants to rev past like 7 when im at that sorta speed .. should it rev till red easily u think ?
PostPosted: 11:12 - 22 Sep 2007    Post subject: Reply with quote
First off, to do decent speeds, especially if the bike's getting a bit tired, you should be going up through each gear to redline, then changing up at the redline.
If you're not doing this, try doing this. Not sure on the gearing, but you'll probably get more power at 120mph in fifth than in sixth, so if there's more go in fifth that might get you to a higher rpm in sixth where it's got more power.
However, this sort of issue is usually more associated with peaky two strokes rather than older 600s.
Fawbish
PostPosted: 11:32 - 22 Sep 2007    Post subject: Reply with quote
If it wont rev past 7, I reckon its restricted mate. Resriction does not limit how fast you can go through the gears, rather what revs you can reach in each gear, like G said.
but if it wont rev past 7, 120mph with a 10% out speedo, could easily be restricted, my zx6 did just under 115 (probs about 110 true) and didnt rev past 9 when I had my restrictors in Thumbs Down
Get it to a mechy mate, or to a garage, they can have a look for you. Try getting a mate though, cos garage will charge labour for looking Thumbs Up
bladerunner
PostPosted: 12:14 - 22 Sep 2007    Post subject: Reply with quote
If your doing 7K in top you aint riding it right. you should be in 4th at that rate. It's not a car and the 600's and 750's need revs to work properly. Try throttle to the stop and change up just before the red line.through the gears..See how fast it goes then. A lad down the road bought a vfr750 off me a couple of months ago and could only get 130 out of it..Until he learnt to give it some through the gears Rolling Eyes now he reports an indicated 150+
I've also just derestricted a honda hornet and with the restrictors in (Honda factory) it wouldn't pull more than 90mph at 8K rpm..so your revs vs speed sounds to be miles out!!! @17mph/1000 rpm
My blade is geared for 15mph/ 1000 rpm in top I dont think your cbr600 should be geared higher than a bike with 50%more cc Shocked Shocked
Robby
Dirty Old Man
PostPosted: 00:16 - 23 Sep 2007    Post subject: Reply with quote
Bullshit alert.
Restrictors limit the amount of air (and therefore fuel) that the engine can suck in, thereby stopping the engine from developing high torque and high power.
Restriction does limit how fast it goes through the gears, and does not limit the revs - you could still redline it in the lower gears, it'll just take longer to get there.
PostPosted: 19:45 - 23 Sep 2007    Post subject: Reply with quote
robby wrote:
Bullshit alert.
Correct Robbie, unless it's a max speed restriction, but this seems unlikely as it's a UK bike.
Just so you know, "only" managed 140 on my Hornet 6(Same basic motor, barn door aerodynamics) one night, changed up from fifth too every(stock gearing, it's mega over geared), next evening nearly redlined it fifth, hit 155, so stop being a girl and hit that limiter it won't go bang(Note I can't be held responsible if it does)
[/bracket attack]
prawny1
PostPosted: 19:16 - 24 Sep 2007    Post subject: Reply with quote
Find a nice long road and nail it in the higher gears you may be suprised at the pull in top at higher revs. sounds to me that you are just holding back on the throttle a bit if your getting 120 at 7000rpm you can easily drop a gear or two and then nail it to the red (but never over).
hellkat wrote:
prawny1
PostPosted: 19:21 - 24 Sep 2007    Post subject: Reply with quote
As far as restictors go most restrict airflow only, restricting your throttle would have the same effect, incidently is your throttle cabl e correctly adjustd and are you getting a full 90 degree rotation of your carb butterflies?
PostPosted: 20:17 - 24 Sep 2007    Post subject: Reply with quote
I don't agree with some of the comments above - the bike should make it to redline in top (supposing it's capable) no matter how early you change up the gears.
Once the revs have passed peak torque in top there should be no less reason for it to pull to the redline than if it had been thrashed to the limiter in every gear before. All that would change is the overall time it would take to accomplish it.
PostPosted: 21:07 - 24 Sep 2007    Post subject: Reply with quote
It may not have passed peak torque by 7000 rpm.
This is definitely an issue on smaller bikes like 125cc 2 strokes, especially unfaired ones.
However, I wouldn't expect of a 600 of that age in decent nick to have the same problem really.
PostPosted: 23:02 - 24 Sep 2007    Post subject: Reply with quote
Well yeah but any bike that is accellerating should keep accellerating until drag overcomes power, no matter how low the revs when starting out. The example of small strokers is about the only time I could envisage where there could be two such occasions in one rev-range. No four-stroke would do it.
The last post was made 18 years, 329 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.29 - MySQL Queries: 16 - Page Size: 129.71 Kb
