does a aprilla rs carb manifold fit a?
mattjs895
PostPosted: 22:46 - 21 Sep 2007    Post subject: does a aprilla rs carb manifold fit a? Reply with quote
cagiva mito barrel.
does anyone know, as i have jsut got myself a 34mm dellorto carb but can only find a manifold for the rs.
cheers
matt
hmmmnz
PostPosted: 22:57 - 21 Sep 2007    Post subject: Reply with quote
why not carve out your rubber carb rubber to fit,
i gather thats what your talking about??
why not just buy the aprilia piece, and mod it to fit your bike,
i think its worth the effort, mabbe it'll fit with no modding :d
good luck Thumbs Up
the humans are dead
I kick arse for the lord
mattjs895
PostPosted: 23:11 - 21 Sep 2007    Post subject: Reply with quote
there the same size (see pic)
is it possible to put a like band around then clamp on, as i am only wanting to do this as a temprary thing
hmmmnz
PostPosted: 00:06 - 22 Sep 2007    Post subject: Reply with quote
nah not really, the distance away from the head alter the proformance as well, i would try and get the aprilia one and try bodge that, or get some one to make you one, you can get carb boots with no holes drilled, pass as to where over here in the uk, but they are available.
good luck mate Thumbs Up
the humans are dead
PostPosted: 00:08 - 22 Sep 2007    Post subject: Reply with quote
Pretty sure it won't fit, and not really sure why you want it to fit. Early Cagiva Supercity used the Mito engine (essentially) but with the 34mm VHSB carb. Only problem is it angles it to one side.
mattjs895
PostPosted: 09:38 - 22 Sep 2007    Post subject: Reply with quote
that would be even better if i could get one of them,
does anyone know anywhere that does them
cheers
matt
hmmmnz
PostPosted: 11:24 - 22 Sep 2007    Post subject: Reply with quote
try https://www.tonymoto.co.uk/
the humans are dead
cagiva gezzer
PostPosted: 18:08 - 23 Sep 2007    Post subject: Reply with quote
One on ebay at the moment. The std manifold does stretch to fit the vhsb.
Got luck jetting it.
cagiva gezzer
PostPosted: 18:30 - 23 Sep 2007    Post subject: Reply with quote
https://i67.photobucket.com/albums/h294/supercitybity/Cagiva/DYNO1.jpg
Set up on the dyon by Road And Track at Aylesbury.
The last post was made 18 years, 352 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 60.55 Kb
