| Yoko |
 Yoko Brolly Dolly
 Posted: 23:06 - 22 Sep 2007 Post subject: Playing with suspension... |
I been thinking about playing with the suspension settings on my ZX6R. At the moment I find its too hard and throws me all over the place. It's never really used on track so doesnt need to be super hard.
Without going in to too much detail about the physics of it where do I start?
I have adjustments at the top and bottom of the forks by way if little screw thingys and the rear suspension can adjust the pre-load by way of big nut above sprint and there is also a little screw thingy on the cylinder thing attached to the top of the rear shock.
Please bear in mind I'm an idiot when it comes to suspension though I'm quite mechanically minded!
Yes I'm aware it would probably be better to get it set up at a garage but I want to play and learn something!
Cheers!  ____________________ Sheep Shagger |
| Irezumi aka Reuben |
 Irezumi aka Reuben Carrot Top
| TUG |
 TUG World Chat Champion
| Yoko |
 Yoko Brolly Dolly
| Davo |
 Davo Davo To The Rescue!
| G |
 G The Voice of Reason
 Posted: 08:20 - 23 Sep 2007 Post subject: Re: Playing with suspension... |
As Davo says, I'd be tempted to splash out and pay someone to do it, if you can. There are a few half decent guides out there that you can google that will probably be better than what most people on here can explain.
I generally pay someone for my race bikes, though have got to the point where if there's obvious problems I can generally fix them.
Setting the static sag is a good start and easy to do. (Google for it, I always get the front and back measurements mixed up .)
Note that for track as well as road riding you generally want the suspension to be as /soft/ as possible without bottoming out. However for track, this is still generally quite stiff.
A good way of measuring this is to put a cable tie over a front fork stanchion. Slide it up against the seal, then as you ride it will get pushed down. If it only ever goes half way down even with heavy braking, etc; then you know you're not using the full range of travel.
Note that while compression damping can be tweaked to change how soft or hard a fork feels, in the end if it's too far out, you'll need to get new springs. Made a decent difference putting heavier springs in my 675. |
| Yoko |
 Yoko Brolly Dolly
 Posted: 08:36 - 23 Sep 2007 Post subject: |
Well I suspect the fork oil most definitely needs doing since its not been looked at for 35k Not sure how much it's going to cost thought.
I'm probably looking at a 'quick fix' at the moment but realistically with suspension there isnt such thing as quick!!
I expect if I get it setup correctly it will give me a bit more confidence and the main thing that puts off leaning the bike more than I already do is because its so twitchy on anything less smooth than glass!
Cheers folks  ____________________ Sheep Shagger |
| G |
The last post was made 18 years, 350 days ago. Instead of replying here, would creating a new thread be more useful? |
