Clutch adjustment
Damon
PostPosted: 14:33 - 23 Sep 2007    Post subject: Clutch adjustment Reply with quote
Hi,
Finally got a mechanic to have a look at my bike. Turns out it was the powervalve. Carbon deposits had made it stick.
Anyway... I need to adjust my clutch so it engages sooner. I have turned the screw on the level all the way out. But it still needs to be sooner. How else can i adjust it.
RS125 06/07 model. Thanks guys Mr. Green Thumbs Up
Paddy Blake
PostPosted: 14:48 - 23 Sep 2007    Post subject: Reply with quote
Turn the screw at the lever in and not out.
PostPosted: 15:37 - 23 Sep 2007    Post subject: Reply with quote
is there not an adjuster further down the cable or where it attaches to the clutch fork arm?
DRZ-400sm
stirlinggaz
PostPosted: 00:26 - 25 Sep 2007    Post subject: Reply with quote
not sure if im understanding you,
if you want to tighten up your clutch cable,
so you dont have to pull lever too far,
& adjuster nut is screwed out,
cable needs tightened at clutch end.
but you need the special tool!
looks like a handle type thing,
your local shop should do it for you,
but you cant tighten it too much as it ruins your clutch.
pic of tool is in handbook.
GAZ
PostPosted: 00:37 - 25 Sep 2007    Post subject: Reply with quote
Main adjuster is inside the clutch cover. There is an inspection hole in the middle of the clutch cover to adjust it. Get the adjustment right with that first, and then use the adjuster on the bars to adjust the free play.
The last post was made 18 years, 362 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 6.35 - MySQL Queries: 13 - Page Size: 44.03 Kb
