quick question...
LUXY DJ
PostPosted: 12:32 - 24 Sep 2007    Post subject: quick question... Reply with quote
right, the crankcase breather tube goes from the crankcase to the rear of the airbox... & if i leave it off when running, it gives out a white-ish smoke(normal i know) & also gonna make warm air go in the box aswell... my question tho, is this plugged into the back of the airbox just to meet emission laws? cause im sure this is why my airbox gets oil inside cause where the tube connects is where theres always oil running down from, SOOOOOO can this be left off? as it can still breath(probs better infact) & also doesnt chuck all its shit into my airbox....
anyone confirm this tho?
also it was doing this before i was wheeling
GSXR750
Jamie S
PostPosted: 12:46 - 24 Sep 2007    Post subject: Reply with quote
The oil mist goes in to the air box to automaticaly oil the air filter ( I assume its a foam one ?)
Oil on the foam filter element helps to stop the fine particals of road dust ect getting through.
LUXY DJ
PostPosted: 12:59 - 24 Sep 2007    Post subject: Reply with quote
na, its a K&N filter, so not just a peice of foam + the oil is coming from the crankcase which is dirty oil & plus it's warm air which is also not good so it deffo aint for that
+ i oil it with special K&N filter oil
GSXR750
Jamie S
PostPosted: 13:03 - 24 Sep 2007    Post subject: Reply with quote
Ah ok , can't help you then sorry.
NSR Mick
PostPosted: 13:28 - 24 Sep 2007    Post subject: Reply with quote
Where did you dream that up from?
jimbothe
PostPosted: 13:46 - 24 Sep 2007    Post subject: Reply with quote
Sounds like it's breathing heavy to me if it's spitting oil back through the pipe.
I thought they put crank breathers in the bottom of the airbox to save leaving them trailing and thus spreading oil all over your back tyre but im sure someone will be along to tell me im wrong Wink
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
Robby
Dirty Old Man
PostPosted: 13:48 - 24 Sep 2007    Post subject: Reply with quote
The same place is he dreams up all of his shit advice.
Luxy - the crankcase breather doesn't have to go into the airbox, but if its venting to atmosphere you should get something on the end of it - very small K&N filters are designed just for this. If you don't, you have a hole in your engine that is both pushing out and pulling in gas - which means it could pull some grit right into your engine.
Also the tiny amount of hot air its venting into your airbox isn't enough to upset the mixture or cost you more than about a quarter of a pony.
LUXY DJ
PostPosted: 14:28 - 24 Sep 2007    Post subject: Reply with quote
cheers
iv been reading up on all this since posting via google, & its either a filter on the end of the breather hose(which you said & probs what i'll go for) or a whole kit that goes from the oil filling hole to join up with the breather hose meaning it all circulates round the engine & never goes into the air filter... leaving the air filter without getting any dirty,oily,contaminated, & slightly warm air on to/in to it
GSXR750
veeeffarr
PostPosted: 15:08 - 24 Sep 2007    Post subject: Reply with quote
What the fuck?
Jamie S
PostPosted: 15:24 - 24 Sep 2007    Post subject: Reply with quote
Like this but 4 stroke Honda's do it automatically.
https://www.trialscentral.com/forums/index.php?showtopic=13974&hl=air+filter
NSR Mick
PostPosted: 15:28 - 24 Sep 2007    Post subject: Reply with quote
No they dont.
steveh
PostPosted: 15:37 - 24 Sep 2007    Post subject: Reply with quote
jamie try not to spout utter shit, you could cost someone a lot of money with your worthless advise, or even get someone hurt.
im sure you mean well, but if your not sure, dont post, as it probably wont help.
as said, ikkle filter Thumbs Up
veeeffarr
PostPosted: 16:01 - 24 Sep 2007    Post subject: Reply with quote
Have you seen his genuine post about welding up the cush drive and bolting the sprocket directly to it?
It won't be long before someone is killed listening to the crap he spouts
PostPosted: 16:34 - 24 Sep 2007    Post subject: Reply with quote
The Speed Fours are notourious for this, here is what some guys do.
https://i80.photobucket.com/albums/j176/twolaneblacktop/100_0838.jpg
Jamie S
PostPosted: 16:52 - 24 Sep 2007    Post subject: Reply with quote
Nothing wrong with doing it , think you will find my bike takes a LOT more abuse and has lot more power than an Xr125.
Jamie S
PostPosted: 16:54 - 24 Sep 2007    Post subject: Reply with quote
No they don't.
Well my tlr does it , My Tl125 used to do it and so does my honda engined lawnmower.
veeeffarr
PostPosted: 17:00 - 24 Sep 2007    Post subject: Reply with quote
You don't ride on the road Jamie... I'd rather fall off on grass than under a bus...
virus
PostPosted: 17:56 - 24 Sep 2007    Post subject: Reply with quote
An xr is cooler though because its road legal Laughing
John
own: 81 xs1100g...
NSR Mick
PostPosted: 18:00 - 24 Sep 2007    Post subject: Reply with quote
Their not supposed to.
LUXY DJ
PostPosted: 19:57 - 24 Sep 2007    Post subject: Reply with quote
Laughing Laughing Laughing Laughing Laughing
im done but it seems you lot aint Mr. Green
GSXR750
Jamie S
PostPosted: 20:01 - 24 Sep 2007    Post subject: Reply with quote
The manual's say they are supposed to.
TheShaggyDA
Repost Police
PostPosted: 20:02 - 24 Sep 2007    Post subject: Reply with quote
/jamie mode on
You could always direct the breather pipe at the chain and avoid having to get a scottoiler.
/jamie mode off
Philious
PostPosted: 14:40 - 25 Sep 2007    Post subject: Reply with quote
Careful Toby or you'll have all the zealots whacking you with abusive ratings because they love him, i called him a twat and got that. Yet others have done the same and no one bats an eyelid.
My honda has this crankcase breather going into the airbox also, the manual states this is due to the emissions. Blow-by gas is returned to the combusion chamber/s through the air cleaner and carbs.
Shaggy ur a funny dude Thumbs Up
Previously; Honda XR125 - Yamaha DT125r - Aprilia Rs125 - Suzuki GS500e, Currently; Kawasaki ZX6R + ZX10R
Theory : Passed 28/7/09 Module 1: Passed 21/09/09 Module 2: Passed 23/09/09
The last post was made 18 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 122.39 Kb
