| Louise |
 Louise World Chat Champion
| Stiffler |
 Stiffler World Chat Champion
 Posted: 09:19 - 21 Sep 2007 Post subject: |
Give or take yes... You'll need to push the piston('s) back into the calliper a little to allow you to fit the new pads in. But this should be easy as long as they aren't suffering from corrosion.
While you've got the calliper off you should give it a quick clean out with brake cleaner fluid.
Finally you'll need a tiny bit of copper grease for the back of the brake pads to reduce brake squeal.
Tim ____________________ Current Bikes - Kawasaki ZX-6R (636) | BMW G650GS |
| cheekythomas |
 cheekythomas Crazy Courier
 Posted: 19:09 - 21 Sep 2007 Post subject: |
If its the bandit that needs the pads... prey to god its been well serviced and copper slipped up or the rear pads can be a proper nightmare as the pins sieze up and often mean spliting the caliper in half to get them out  |
| alun111 |
 alun111 World Chat Champion
| Louise |
| Drew |
 Drew Banned
| carvell |
 carvell Scuttler
| Louise |
| carvell |
 carvell Scuttler
 ---- World Chat Champion
 Posted: 16:08 - 23 Sep 2007 Post subject: |
yup g clamp.
what suprises me is that youve let the pads go that far before changing them your lucky you dont need a new disk aswell.
good luck ____________________ DRZ-400sm |
| Louise |
 Posted: 16:14 - 23 Sep 2007 Post subject: |
As above I cant get the caliper off. One of the bolts is stuck - the more we try to undo the more its rounding off.
Well, I had a blonde moment and decided to ride a few miles with out relising I had the back brake on
Ringing garage tommorow.
Thanks for the help tho  |
 Posted: 16:22 - 23 Sep 2007 Post subject: |
is there enough room to get vice grips onto the bolt?
get them on nice and tight that should get it off.just make sure you replace the bolt with a new one afterwards. ____________________ DRZ-400sm |
| Louise |
| Drew |
 Drew Banned
| Louise |
| snapperslappe... |
 snapperslappe... Scooby Slapper
 Posted: 17:42 - 23 Sep 2007 Post subject: |
had the same problem getting the rear caliper off.... i just hammered an imperial socket onto the bolt head ( ever so slightly smaller ), stuck an extention bar onto the ratchet arm and tapped it off with a mallet.....
just make sure you've got a sutable replacement bolt to hand.
the only other wat would be to whip the rear axel out, the caliper holding bracket will then move down enough from the disk for you to g clamp the pistons  |
| sickpup |
 sickpup Old Timer
| sickpup |
 sickpup Old Timer
| Louise |
 Posted: 14:01 - 24 Sep 2007 Post subject: |
Scoket set was tryed yesterday just rounds off.
Going home shortly and will try the things said on here  |
The last post was made 18 years, 352 days ago. Instead of replying here, would creating a new thread be more useful? |
