Honda CB400 (NC31) Very dim headlight!
AngelGrinder
PostPosted: 09:35 - 25 Sep 2007    Post subject: Honda CB400 (NC31) Very dim headlight! Reply with quote
My MC31's headlight is terrible, it even looks dim when you look at it from the front, is this a usual problem with these, or is it just a crap bulb?
If it is a usual problem, what's my best best to improve the light without breaking the bank?
Cheers!
djrichieb
PostPosted: 12:51 - 25 Sep 2007    Post subject: Reply with quote
The light on my super four is about the same brightness as a car light. Very good for dark roads.
It could either be your bulb or the battery?
Rides: Honda CB400 SF (ART can) - Citroen Saxo 1.1i SX
TUG
PostPosted: 14:03 - 25 Sep 2007    Post subject: Reply with quote
i'd say wrong bulb, too high wattage, or like djrichie said, could be your charging system, but more than likely its just the bulb.
Haz ER-5, innit!
Andyco11
PostPosted: 16:21 - 25 Sep 2007    Post subject: Re: Honda CB400 (NC31) Very dim headlight! Reply with quote
Cheers!
Is it dim all the time?
or only when the engine is not running or idling?
Dose it get brighter when you rev the bike?
XS250 Special - XS250 US Custom - XS250 Special Jap Import with YICS Engine
The Florida Forum
AngelGrinder
PostPosted: 17:55 - 25 Sep 2007    Post subject: Re: Honda CB400 (NC31) Very dim headlight! Reply with quote
Cheers!
It's dim all the time and does not get brighter if I rev it, it does dim even more if I apply the brake (presumably as the rear brake light is also drawing power)
The battery is possibly low, as it was flat last month and I had to bump start it, but I have been riding around a fair bit with the light on dipped beam to try and keep it charged.
Andyco11
PostPosted: 18:24 - 25 Sep 2007    Post subject: Re: Honda CB400 (NC31) Very dim headlight! Reply with quote
Sounds like you have two problems
1, battery is shaged
2, you could have a possible alternator / dynamo fault
If you disconnect the battery dose the bike still run if not it your charging system
The Florida Forum
The last post was made 18 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 50.85 Kb
