Just spit balling, but an idea for winter rubber?
Whosthedaddy
PostPosted: 09:36 - 25 Sep 2007    Post subject: Just spit balling, but an idea for winter rubber? Reply with quote
Had me thinking the other day with the thought of winter just around the corner.
Would the use of tyre warmers over night (or maybe set on a timer just before you get up) help with the initial part of the daily commute?
We would have been living in the sticks and the commute would have started with some serious twisty bits and would having a hot set of rubber be beneficial or is a hot tyre on cold road a no go?
The second part of my quandary was the use of sports tyres in the cold dank months. I've currently got Diablo Corsas front and rear and although they do feel exceedingly planted when dry, in the damp the rear wheel has skidded a few times when down shifting and the sure footed ness of sticky rubber feels less than inspiring over the past few horrid days.
ram_doom
PostPosted: 09:42 - 25 Sep 2007    Post subject: Re: Just spit balling, but an idea for winter rubber? Reply with quote
WTD, if your tyres are in good nick, your better off having them taken off, replaced with something cheap like "contiforce", which are "ok", then riding carefully around during winter, thus keeping the diablo's fresh for warmer months.
TL1000s, KDX200
Kal
PostPosted: 09:49 - 25 Sep 2007    Post subject: Reply with quote
I suspect the tires would have cooled off before the heat could be useful.
I'd be inclinded to gop with ram_doom on this one and get yourself a nice set of sport touring tires for the "off season."
Kal...
killa
Won't Shut Up
PostPosted: 10:03 - 25 Sep 2007    Post subject: Reply with quote
Bridgestone Battlax's 014's all year round Thumbs Up
h00dwink
PostPosted: 10:23 - 25 Sep 2007    Post subject: Re: Just spit balling, but an idea for winter rubber? Reply with quote
Isn't that essentially just the same as using the current tyres now and just replacing them for a new set in the summer?
Would cost less getting them changed like that aswell. Unless he has his own fitting machine that is.
Sahf East Winnah 4LYF
https://bikepics.com/members/h00dwink/00sv650s/
www.youtube.com/h00dwink updated regularly
veeeffarr
PostPosted: 10:35 - 25 Sep 2007    Post subject: Reply with quote
This is why I use sport-touring tyres Wink
Pilot Road2
ram_doom
PostPosted: 10:46 - 25 Sep 2007    Post subject: Re: Just spit balling, but an idea for winter rubber? Reply with quote
Contiforce tyres = £110 quid a pair and say £15 - £20 for fitting on his loose wheels.
That way he has a tyre with good wet weather grip, and saves having his expensive race tyres squared off through winter riding, requiring a new set at a premium summer price at the end of winter Smile
TL1000s, KDX200
PostPosted: 11:22 - 25 Sep 2007    Post subject: Re: Just spit balling, but an idea for winter rubber? Reply with quote
In my experience, having good wet weather grip and being designed as an ‘all round’ tyre don’t always coincide.
Some tyres designed for all round/touring don’t have very good wet weather grip, while some tyres designed for sporty use have very good wet weather grip.
The first and most important factor in this in my experience is the tyre compound used. If a tyre is sticky from cold in the dry, it’ll probably be relatively the same in the wet.
In the past it’s been mentioned that a compound high in silica should grip well in the wet.
I have used Supercorsa race tyres on my TRX back to back with two touring tyres. The Supercorsas would have enough grip to wheelie after about a mile’s riding in damper conditions than the touring tyres. It’s not so great having loads of tread to disperse water if you don’t have grip in the first place.
After that, how quickly the tyre warms up can be important, especially when riding in cold weather. A tyre with lots of tread will allow the rubber to move around more, which will heat it up quicker. However, of course this may be counteracted by a hard compound of tyre which naturally doesn’t flex as much.
A hot set of rubber would be beneficial on cold roads. However, it’s unlikely that you’ll be riding at a level that will keep that amount of heat in the tyres. So with tyre warmers you’ll see lots of grip to start with, which will then trail off leaving you with less as you get into the riding.
In my experience this is a dangerous combination, as at the point you’re just getting into it and getting some confidence, your tyres are losing grip and becoming worse, yet your confidence is based on the hot tyres a few minutes ago.
If it was a lighter bike, I’d recommend some road-legal intermediates or wets which are popular with supermoto riders. However these would get chewed up very quickly on a heavier bike, I suspect.
In conclusion, err, ride smoother Smile.
The last post was made 18 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 60.71 Kb
