Alternative to battery
Cigaro
PostPosted: 14:13 - 25 Sep 2007    Post subject: Alternative to battery Reply with quote
Well the original battery that came with my scooter is shagged (many years old and it's never been used), a replacement only costs £25 but I've literally no use for it as I don't mind kickstarting it, so I'll never use the leccy start.
However, at idle the headlight is quite dim and the indicators won't flash at a constant rate - I've tried turning up the idle but the point at which things start to work properly is the point at which the bike tries to 'creep' forward if the brakes aren't on. So I'm assuming the alternator is quite weak.
Is there anything I can do about this, apart from buy a battery which I'll never use?
Andyco11
PostPosted: 16:25 - 25 Sep 2007    Post subject: Reply with quote
That's because your bike was designed to work with a battery
so that all your electrics work at tick over put a new battery in it
XS250 Special - XS250 US Custom - XS250 Special Jap Import with YICS Engine
The Florida Forum
Finglonga
PostPosted: 16:36 - 25 Sep 2007    Post subject: Re: Alternative to battery Reply with quote
Er.....You do use it. To power the lights and indicators and all other electrical things on the bike. As said, if it wasn't needed they wouldn't put a battery on it.
Andy Sez....
F.Y.Y.F.F.
alun111
PostPosted: 17:23 - 25 Sep 2007    Post subject: Reply with quote
I'm pretty sure you'll need one for the MOT anyway...
Cigaro
PostPosted: 17:25 - 25 Sep 2007    Post subject: Reply with quote
There's no battery required for the MOT, but if the lights don't work it's probably a failure.
I'll just bite the bullet and buy one. Cheers for the advice Smile
The last post was made 18 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 47.57 Kb
