Oil vs Air
Whosthedaddy
PostPosted: 10:43 - 26 Sep 2007    Post subject: Oil vs Air Reply with quote
When it comes to a cooling system, any pros or cons with either?
Nath
PostPosted: 11:33 - 26 Sep 2007    Post subject: Reply with quote
Air cooling doesn't work so well on bigger more powerful bikes.
I have an xs750, and they are well known for being liable to overheat. It's a three cylinder engine, and it's the middle pot which gets it the worst. The later 850cc model had an oil cooler fitted as standard, and plenty of people retro-fit one to the 750, as indeed I have done.
That said, Bandits are oil cooled and have hardly any finning on the head yet are not really known for cooling problems. Maybe it was just suspect 1970s design which made the bigger engines prone to overheating.
Both oil and aircooled engines are massively easier to work on.
Hard livin', hard luck.
Whosthedaddy
PostPosted: 18:35 - 26 Sep 2007    Post subject: Reply with quote
Just curious to be honest as the monkey is air cooled and there are loads of after market oil cooling systems as means of an upgrade.
I'm all for simple Laughing
bish777
PostPosted: 19:13 - 26 Sep 2007    Post subject: Reply with quote
I'd say it'd be fine aircooled as stock. Youll only really need to start upgrading the cooling if you indulge in some tuning.
70s and older aircooled machines can be tempremental when out of the wind but 80's on most aircooled lumps, particularly large capacity, were pretty sorted and reliable.
Oilcooling can be added to alot of aircooled motors by putting a radiator in the oil circulation at some point in its circulation.
A true oilcooled motor does not rely on aircooling, and has a more complex oil cooling setup, the example being the bandits (which are unsing the original GSXR lump). They have alot of oil jets and sprays that circulate oil to the various of the motor at high pressure and sprays oil on the underside of the pistons. Oilcooled motors run nearly as cool as watercooled engines, and this was the reason why they were used in the original GSXR750 and 1100s. The oilccoliong meant unrestricted power outputs but were at the time lighter than a watercooled engine.
GSXR1100J
PostPosted: 22:26 - 26 Sep 2007    Post subject: Re: Oil vs Air Reply with quote
Oil-cooled is better by far.
The heat-transfer from alloy-oil is much greater than alloy-air, so you can build a more compact engine and cool it better. Oil can also take heat away from parts of the engine not exposed to cooling air i.e. internal parts. Whilst air is used to cool the heat-exchanger (oil-cooler) it's a large volume over a large surface area so it can keep up with the heat put into the exchanger by the low volume of oil putting a lot of heat into a low surface area (the oil-tubes of the cooler).
The last post was made 18 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 46.12 Kb
