How To: Removed Collapsed Bearings
Aikman666
PostPosted: 00:00 - 27 Sep 2007    Post subject: How To: Removed Collapsed Bearings Reply with quote
https://deliverator.silverfir.net/gallery/albums/Flotsam/farnsworth_finglonger1.jpg
Ok, so like me, if one of your bearings say, in a wheel collapses and your left with the outside race in there and are TRUELY stumped as to how to get it out, fear not, Aikman has a solution!
1. Hold wheel vertically, as verticle as you can get
2. Load all the ball bearings you have left into the outside race until it reaches half full
3. Slide the inside race in, applying pressure onto the bearings
4. Flip wheel horizontal with the bearing facing UP keeping pressure
5. Use a small screwdriver to space out the balls as equally as you can get
6. Pressure the inside race TOWARDS you to prevent the balls moving
7. Flip the wheel so the bearing is now facing DOWNWARDS, ontop of two peices of wood, spaced wider than the bearing
8. Smash the shit out of the inside race from the other side
9. Complete bearing pops out - Great success
10. Celebrate
So if your ever faced with this situation, now you know. It had quite a few people stumped (credit to Banditshigh for the idea!)
Will work for petrol
My Design Blog
steveh
PostPosted: 00:07 - 27 Sep 2007    Post subject: Reply with quote
Or failing that, take it to work and use the bearing puller Thumbs Up
ive had a few bad bearings in my time, dremmels are somtimes good if there really bad (and you have a steady hand)
sounds like you had fun anyway, no smashed knuckles? Laughing
Aikman666
PostPosted: 00:10 - 27 Sep 2007    Post subject: Reply with quote
Your plan would have been good except from 2 vital flaws
A. I dont have a bearing puller
B. I dont have a dremmel
Otherwise i would have just skipped this whole fucking carry on and popped it straight out Laughing And I did strangely have fun. I sat on my garage floor in disbeleif after 2 days of prising, heating, spraying, hitting, crying, swearing it came out like that! And no skint knuckles funnily enough, cut my finger on the saw though Thumbs Up
My Design Blog
steveh
PostPosted: 17:43 - 27 Sep 2007    Post subject: Reply with quote
i was about to say the same, beating your bike with a hammer when your pissed off with it can be quite soothing :uP:
Visitor Q
$25 whore
PostPosted: 14:15 - 28 Sep 2007    Post subject: Reply with quote
Or rather the moment when your wheel gives birth to a bearing...
I just hate that point of no return, when you've hammered the bearing about already and dont trust it would work.
So you spend another few days 'drifting' it with a 4lb lumb hammer and a chisel.
SoND
PostPosted: 17:00 - 28 Sep 2007    Post subject: Reply with quote
My way:
Get a crowbar that will fit under the outer race enough to get a grip and start to lever it out. The crowbar will be working against itself holding it tight in so use a metal bar to hammer at the crowbar from the other side and this should slide it out.
The last post was made 18 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.79 - MySQL Queries: 13 - Page Size: 50.66 Kb
