Car MOT
cagiva gezzer
PostPosted: 13:25 - 28 Sep 2007    Post subject: Car MOT Reply with quote
Just giving my friends Golf a once over before the MOT.
What i know
Tyre is slit, assuming it's a fail.
Rear brake binding, will fail if it binds again.
What i need advice on
How bouncy is bouncy when it comes to spotting failed dampers? I drive a car with sports suspension, so this golf feels like a bouncy castle. Is it just down to each mechanic?
If a car is fitted with a rear windscreen wiper, does it have to work? i.e. this one won't work.
biglee
PostPosted: 14:08 - 28 Sep 2007    Post subject: Reply with quote
Tyre is a fail
binding brakes Fail
wiper shouldnt be a fail
if the suspension keeps bouncing after you push it, then the damper is f#cked and it will fail.
good luck
Drew This post is not being displayed because the poster is banned. Unhide this post / all posts.
Nb
PostPosted: 18:22 - 28 Sep 2007    Post subject: Reply with quote
Rear wiper isnt tested so dont worry about that (front wipers are tested for operation and their job of clearing the screen)
As for tyres...C.
Condition of Tyres
1. Examine each tyre for a. a tyre has a cut the length of which is at least 25 mm or 10% of section width, whichever is greater, deep enough to reach the ply or cords
b. lumps, bulges, tears, exposure of the ply or cord, or tread separation
Note: On radial ply tyres, care should be taken to distinguish between normal undulations in the carcass, resulting from manufacturing, and lumps or bulges caused by structural deterioration b. a tyre has a lump, bulge or tear caused by separation or partial failure of its structure. This includes any lifting of the tread rubber
any of its ply or cord exposed
As for shocks they have to be pretty darn bad to fail....
A shock absorber which has negligible damping effect.
When you bounce it once how long does it continue to rise and fall?
Is their no way you can fix the binding brake?
cagiva gezzer
PostPosted: 18:52 - 28 Sep 2007    Post subject: Reply with quote
Brake - wheel off, wiggle the calliper. Freed it up, but the rear side of the disc has only had 30% of the surface worn, the rest is rust. Near side of the disc is grooved.
Works now, but i didn't drive it.
Suspension. Just feels rather wobbly. Doubt its as bad as i make it out and kwickfit had just replaced the rear dampers (and didn't fit any boots), so i assume the checked the fronts.....
It gets a few oscillations, and coming to a heavy stop makes it wallow.
TBH, sod her, she picked it up and belted off, hardly noticing that i'd taken dents out and polished out the reds / blues / blacks from the silver paintwork from where she'd rubbed things.
Was also off the bottom of the dipstick for engine oil. - VW TDI1.9 . . . . . . .. Confused
The last post was made 18 years, 327 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 45.11 Kb
