New GS125 problem! Starter motor?
ttr
PostPosted: 18:45 - 01 Oct 2007    Post subject: New GS125 problem! Starter motor? Reply with quote
Right! Sorted out the previous bolt woes, and wired in the new headlamp today, thankfully that worked without any complaint, so woot. The ticker for the indies doesn't seem to be working, but could that be because there's only one indicator wired in at the moment?
However, this is the more serious problem at the moment;
Earlier it was starting without complaint, now however, when I push the electric start button, the starter motor does its thing for a few seconds, then a sort of clunky-thud noise can be heard, and nothing happens.
The fuel tap is not set to off, this time! Embarassed Laughing
Anyone got any thoughts?
[edit]
Right, just went down to the garage to try again on a whim, and it worked this time.
The question now is, why wouldn't it have worked before? Is this a problem I should be worried about, or is there some really simple answer? Is it likely to crop up again?
Cheers in advance!
GS125-> NT400->VFR400->CRM250->Z750 + GS125->NTV650 rat + VMX1200->GSF600 + GPz550
ttr
PostPosted: 15:12 - 07 Oct 2007    Post subject: Reply with quote
Bump
This has resurfaced as being a problem. Started fine for a few days now it's back to going "Clunk" and not starting at all
Anyone got any thoughts? Could use some help here!
timjim
PostPosted: 15:40 - 07 Oct 2007    Post subject: clunk Reply with quote
Have you tried jump starting the bike,just to rule out a flat battery?? Karma
ttr
PostPosted: 16:32 - 07 Oct 2007    Post subject: Reply with quote
If the battery were flat, wouldn't the lights & such not work?
All the other electrics seem to be working fine?
The high beam light on the clocks is a bit dim but that's about it..
Paddy Blake
PostPosted: 16:49 - 07 Oct 2007    Post subject: Reply with quote
I would also say it is the battery that is the problem.
The lights will work even when the battery is to low to turn over the
engine.
Paddy.
The last post was made 18 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 44.66 Kb
