Ethernet over Mains???
NSR Mick
PostPosted: 09:46 - 02 Oct 2007    Post subject: Ethernet over Mains??? Reply with quote
Has anyone tried these?
I'm a bit wary as it goes against everything I've ever done, although if they do work it would get me out of a bit of a situation.
I have moved all my pc kit into the garage which has power (obviously) but no phone. the only problem I can forsee is that the garage and house are on different rings.
I need to get the broadband into the garage somehow. At the moment I've got a length of cat5 running from one of the bedroom windows, around the garden and through the garage door and the missus is getting a bit fed up of it now. Wink so if these do do what they say on the tin I'll get a set.
instigator
PostPosted: 09:47 - 02 Oct 2007    Post subject: Re: Ethernet over Mains??? Reply with quote
Wireless? Laughing
Never tried the ethernet over mains myself, bit sceptical about it really.
PostPosted: 09:50 - 02 Oct 2007    Post subject: Reply with quote
Basic networking over mains has been done for ages (there was stuff for doing it in the mid 80s on the Amstrad CPC machines), and broadband over the main has been developed (just that with the way the electricity industry is split up in the country nobody has enough of a stake to make it worthwhile).
Think I would prefer to try wireless though for what you are doing.
NSR Mick
PostPosted: 10:08 - 02 Oct 2007    Post subject: Reply with quote
I tried wireless, the problem I have is that it needs to go from the router to a switch not just 1 machine. I've tried so called wireless bridges and extenders etc with no success.
Colin Edwards
PostPosted: 10:39 - 02 Oct 2007    Post subject: Reply with quote
I have always been taught that power and networking need to be kept as far apart as possible. This is due to the power causing interference to the network signals (when im working on servers racks I always put the network cables one side and the power the opposite)...
Having said that i have had a play with some of this kit as I had my router in one room and wanted internet the other side of the house without using Wifi. Reason for this being that the more devices you connect to the Wifi the more unstable the connections become.
So I got two of the network/mains devices to try out (special deal, Maplins advertised £40 off). First thing I will point out is the devices come in several speeds and you need to check what you buy. I used kit from Maplins that offered 100 mbps (14, 40 and 200 are also available) but its actual threw put was about 40mbps. The more devices you add the slower the connection becomes as you share the data between devices (does not switch or load balance). Qos (quality of service) is available though on some devices and if you know how to set it up worth looking into.
I found the kit suited what I needed as I actually only wanted to take the router connection to a switch and this was more than enough to support my 8mbps link. The pc kit was plugged into a switch which meant I could share the internet connection but also the speed between my computers stayed at 1000mbps (not achievable if I used wifi between all connections).
One thing I must point out is this solution can only be used on a single ring main. Ring mains are isolated from upstairs to downstairs for obvious reasons. If electric cant go from one to the other then there is no way a network signal can. I have read reviews and comments from the teckys on the Maplins site and they say you can but its just not possible…
CE
syl
PostPosted: 11:04 - 02 Oct 2007    Post subject: Reply with quote
If you've got a wireless bridge setup properly and have a decent signal, then you should have no problems at all. It is what wireless bridges are designed for (they are not designed for connecting computers to, simply to replace a piece of cable with a single wireless link). You are obviously doing something wrong or the equipment you are using isn't up to it. Plug a switch into the garage end of your wireless bridge and connect all your equipment into it.
If the signal is a problem, buy a directional antenna (you need kit that supports external antennae). If you are really talking long distance (I doubt it as you currently use cable from a window) then you could look at laser or microwave links.
You might be able to do it cheaply using an access point at one end and one of those little boxes intended to attach to an xbox at the other (but plug a switch into it rather than an xbox) - but for a serious setup, use a proper bridge (preferably the same manufacturer) at each end.
Current bike: Kawasaki Z750S
andrew
Mister Road Rage
PostPosted: 11:39 - 02 Oct 2007    Post subject: Reply with quote
I use wireless and power over ethernet in my house. I've got the solwise 200mbit av power cube thingys, these connect my wireless router in the front of my house to the garage at the bottom of my garden which is like 200ft away. The connection is rock solid and hasn't let me down once.
https://www.solwise.co.uk/
sickpup
Old Timer
PostPosted: 11:47 - 02 Oct 2007    Post subject: Reply with quote
CE
Yes it is.
Ring circuits are isolated from each other by fuses or breakers. They still have a common input when the circuit is live. This is why you can use baby monitors in adjoining houses and on different floors in houses.
I would stay using the Cat5 cable, just hide it.
Colin Edwards
PostPosted: 11:55 - 02 Oct 2007    Post subject: Reply with quote
Maybe in your house but not in mine...
As proven with a quick call to the netgear helpdesk...
I still kept it as a solution though and just use a wifi ap for laptops...
CE
Colin Edwards
PostPosted: 11:57 - 02 Oct 2007    Post subject: Reply with quote
https://www.maplin.co.uk/module.aspx?ITAG=FAQ&ModuleNo=48539&doy=2m10#faq
"Q) Will this work where you have more than one ring main upstairs and downstairs say? - Steve
A) They only function over the same ring main i am afraid"
Just another example
CE
NSR Mick
PostPosted: 13:19 - 02 Oct 2007    Post subject: Reply with quote
I think I will.
That just means drilling holes in the house. Laughing
andrew
Mister Road Rage
PostPosted: 13:21 - 02 Oct 2007    Post subject: Reply with quote
CE
Yes it is.
I'm with you on this, my garage is on a separate ring and it works there, same with upstairs in my house.
Colin Edwards
PostPosted: 13:24 - 02 Oct 2007    Post subject: Reply with quote
Well if must be different from house to house...
I tried it here from office to bedroom and was ok..
Take it any ware downstairs and it stops...
Called netear and they said its not supported from ring to ring so gave up..
Also read a lot of reviews about people that have tried and had no joy.....
CE
If it works for you good but if not there is always wifi...
sickpup
Old Timer
PostPosted: 13:55 - 02 Oct 2007    Post subject: Reply with quote
CE
Possibly the absolute worst quote you could have EVER given.
Considering the feedback above that one says.....
Q) I''ve received confirmation from Devolo that they work on more than 1 ring and I can confirm, that they''re up and running in a house on 3 separate rings without any problems. I hope that''s helpful. - Chris
A) thank you for the additional feedback
NSR Mick
PostPosted: 16:03 - 02 Oct 2007    Post subject: Reply with quote
TBH I cant see why they wouldnt work on different rings.
I would have though issues would arrise if you went outside the main fuse box, which could be an issue as the garage is run off a fusebox in the garage fed off a fused connection in the house.
What I'm going to do is get some from PCWorld of all places on the way home tonight and see what happens.
Watch this space. Laughing
NSR Mick
PostPosted: 19:48 - 02 Oct 2007    Post subject: Reply with quote
They do work on seperate rings. Wink
I have just installed a pair and am posting this with them in place.
Bye bye cable, at least the missus will be happy now. Wink
sickpup
Old Timer
PostPosted: 10:58 - 03 Oct 2007    Post subject: Reply with quote
Do these have any security on them or can they be used to gain access to someone else's system?
NSR Mick
PostPosted: 14:07 - 03 Oct 2007    Post subject: Reply with quote
They do have security, when you set them up the software either generates a key for you (which I did as I dont give a shit what it is as long as they speak to each other) or you can set your own.
If you are going to try these I would say dont bother with the 14mb ones they just dont cut it. I was getting 4-5mb throughput and seing as my broadband does actually run somewhere near 8mb was a bit short.
Luckily one of the plugs had a fault so I changed them for the 85mb ones this afternoon and all seems well. Thumbs Up
The last post was made 18 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.59 - MySQL Queries: 13 - Page Size: 105.13 Kb
