sigma bc1606L wheel size input for my cagiva.
befdelta7
PostPosted: 18:41 - 02 Oct 2007    Post subject: sigma bc1606L wheel size input for my cagiva. Reply with quote
hi,
i have a sigma bc1606L cycle computer, and cant get my head around setting the wheel size. anyone know what numbers to input in the computer for my wheel size?
my wheel on the bike is 110/70/17.
or know of the easiest way to calculate the wheel size? read somewhere that you position the valve at the bottom of the wheel then roll the wheel forwards untill the valve is back at the bottom, then measure the distance travelled im mm... but not sure what to do after this. take the distance in mm and divide it by 1.61(mile)??
iv no idea, anyone got any ideas?
cheers, Thumbs Up Thumbs Up
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
PostPosted: 18:46 - 02 Oct 2007    Post subject: Re: sigma bc1606L wheel size input for my cagiva. Reply with quote
Most push bike style speedos require you to put the size in, in mm or cm. Some do require you to divide the circumference by 1.61 if you require the output in mph rather than kph.
All depends on the model.
You can do the putting the valve on the ground and measure the distance. Someone else mentioned a dab of paint on the tyre then meausre the distance (or tippex). Alternatively a bit of string around the centre of the tyre will also do it.
befdelta7
PostPosted: 19:39 - 02 Oct 2007    Post subject: Reply with quote
thanx G Thumbs Up
the computer i have has the option of kph or mph. i think im going to do the "roll out" test, sounds easiest. so with the computer having the option of kph-mph means that i dont need to divide by 1.61 do i??
the thing is that i dont have a speedo to compare with when setting up the computer, so i need a way to set this up quite accuratly. thanks for the replys.
PostPosted: 19:42 - 02 Oct 2007    Post subject: Reply with quote
befdelta7 wrote:
so with the computer having the option of km/h-mph means that i dont need to divide by 1.61 do i??
It depends, read your manual.
One I have used had this option, however all it did was change the letters showing, not the actual speed displayed. It specified in the manual that you needed to divide the length by 1.61 if you wished to use kph.
befdelta7
PostPosted: 19:51 - 02 Oct 2007    Post subject: Reply with quote
right it shows in the manual,
a little diagram of a bike front tyre with a measuring scale below it, it has:
km/h:
WS = mm
mph:
WS = mm
beside the diagram.
does that mean that selecting the mph option, i dont have to divide by 1.61?
The last post was made 18 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 45.23 Kb
