| fanatic88 |
 fanatic88 L Plate Warrior
 Posted: 18:56 - 02 Oct 2007 Post subject: ns125r questions and oppinions |
Heya evryone , im new here , im boban from Serbia and i ride ns125r from 1989 year... Finaly after 2 years of riding i decided to fix and refresh my bike as much as my budget alows me to . Got few questions to ask , if u got time id appriciate your answers and suggestions.
1st- Would K&N filter give my bike bit more speed/acceleration ? Would he "eat" machine?
2nd- Ive read aloth about 2stroke exaust , learned i cant change the exaust pipe , could i just change the exaust at the end? If i put bigger exaust , from a bigger bike , etc from 600ccm , would it be better or worse?
3rd- As u can see @ the image bellow , there is aluminium part between arrows. Is that intake restrictor? Should i take it off? If i do would it hurt to the engine?
https://upload3.postimage.org/384171/a56e867d1.jpg
4th- Is there any chance installing electrical starter to my ns? If it does what parts do i need?
Id be really thankfull if you could help me ... Cheers!
p.s Bike dont look this bad right now , its being repaired , repainted , im going to paint each part and try to bring it old retro style shine... |
| biker_king |
 biker_king Renault 5 Driver
| ncrn |
 ncrn World Chat Champion
 Posted: 20:37 - 02 Oct 2007 Post subject: |
Well just wanna say the K&N filter won't help a 2 stroke engine at all.
Also a larger exhaust will not help the 2 stroke engine run, its shape is very important to how the engine runs, if anything a bigger exhaust will make the bike slower.
There may be restrictors but I don't know anything about the ns125 I'm afraid. ____________________ Past: 55 Sym Jet, 91 ZZR250, 03 NSR125R. Present: 97 ER-5.
https://www.nsr125.co.uk - NSR Owners forum. |
| fanatic88 |
| ncrn |
 Posted: 00:17 - 03 Oct 2007 Post subject: |
The full system effects the exhaust emissions. You want to keep the whole thing the same so that the bike can pull enough waste gas out of the cylinder.
There may be some plates that you can remove from the inside of the exhaust that will improve the bike, I know there is in the nsr, but then it may be different between the two. ____________________ Past: 55 Sym Jet, 91 ZZR250, 03 NSR125R. Present: 97 ER-5.
| Evo |
 Evo Trackday Trickster
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 00:37 - 03 Oct 2007 Post subject: |
there are plenty of aftermarket exhausts for thensr that will actually give you better performance, the expansion chamber on any 2 stroke is very important, that is where most of the tuning is done,
bear in mind you will have to change your jets in your carb to benifit and exhaust changes usually you get these when you buy a bike specific 2stroke pipe, the silancer on the end does nothing except quieten the bike, you could run without it with minimal ill effects.
you could give the ports a bit of a polish to help things moving more freely,
don't drill your airbox!!! this will only make your bike run like shit,
if you want more performance buy a new pipe!!
edit.... its a ns not an nsr
good luck ____________________ the humans are dead
I kick arse for the lord
| Kickstart |
 Kickstart The Oracle
 Posted: 01:51 - 03 Oct 2007 Post subject: |
NS airbox was a poor design. A K&N / S&B type air filter might well help, although be prepared to play around getting the jetting right. Also have a feeling there was a spacer tube around when the NS was popular to help it work with a single filter.
The bit the arrows points to is the reed block. Not a restrictor (engine would stuggle to run at all without it).
Changing the silencer won't do much. Fitting one from a larger bike will just add a load of weight.
As to an electric starter. Anything is possible (you can get electric start conversions for 60 year old Vincents), but not at a realistic cost.
| Welshd1k |
 Welshd1k World Chat Champion
| fanatic88 |
 Posted: 09:42 - 03 Oct 2007 Post subject: |
Thanks for answers.
@ns125rk90
Can u paint on picture where is that exaust restrictor?
So should i put K&N or not? its NS not NSR
Im planing just to modify silencer , planing to make small slipon silencer for my bike.
@Kickstart
Thanks didnt knew whats that part , tought its intake restrictor... Did u had K&N on ur ns? Thanks. |
| alains |
 alains World Chat Champion
| fanatic88 |
 Posted: 10:07 - 03 Oct 2007 Post subject: |
@alains
Thanks . Could u give me some info about my bike , it seems ur bike fanatic as i am ... Restrictors , what could i do to get better performance or just help my bike to run better?
Best regards , fanatic |
| alains |
| fanatic88 |
 Posted: 10:27 - 03 Oct 2007 Post subject: |
Damn ... Thanks anyway  |
| Kickstart |
| Welshd1k |
| fanatic88 |
 Posted: 16:38 - 03 Oct 2007 Post subject: |
omg i cant decide now ... K&N or Standard ?
Half ppl said no , half said yes ...  |
| fanatic88 |
 Posted: 20:13 - 03 Oct 2007 Post subject: |
Im going to order K&N , its around 30 euros here , so aint much , if it runs better ill leave it , if doesnt just going to send it back to seller wich can be done here. Now he asked me what "FI" , the size of filter i need? I guess i need 26mm one cause charb is 26mm as it says on this link
https://www.motorcyclespecs.co.za/model/Honda/honda_ns125r%2087.htm
Or im wrong? Thanks |
| Kickstart |
 Posted: 20:18 - 03 Oct 2007 Post subject: |
You are wrong. the size refers to the outer diameter of the inlet to the carb (ie, the filter clamps onto the outside of the carb inlet).
The problem people say with K&Ns is that the metal plate at the ends causes pressure waves through the carb at some revs, giving a very rich mixture (and why the Ledar kits came with extension tubes to move the filter further from the carb). The foam Ramair type filters apparently do not suffer this problem.
Order a few spare main jets and be prepared to spend some some playing with the jetting to get it acceptable.
| fanatic88 |
| Kickstart |
| Welshd1k |
| Kickstart |
| Welshd1k |
The last post was made 18 years, 336 days ago. Instead of replying here, would creating a new thread be more useful? |
