| darkangel |
 darkangel Nitrous Nuisance
 Posted: 15:07 - 05 Oct 2007 Post subject: Sound recording of engine prob DT 125 <FIXED> |
Before i book the bike in with a mechanic i would like it if someone could listen to two recordings i made of my engine.
They are in a zip file, two sound files and a txt file explaining what possition the mic is in when recording are inside it.
Here's the link
https://www.megaupload.com/?d=UOKEUEIU
The bike is a Yamaha DT 125R 2-stroke
12k miles on the clock
I dont know how well you can hear the problem on the recordings but basically there is some kind of strange noise comming from my engine around the barrel area, it does not effect performance but it is lound and annoying.
Any ideas what could be causing it?
Thanks
<UPDATE>
I had a rebore done, clearances are so tight now compared to what they were before, i had troubly getting the piston and rings into the barrel the clearance was so small.
The sound is (all but a tiny noise, probably just the noise of an old engine, doesn't bother me) gone now, performance is up noticably, fuel economy up a bit, a new gasket also solved my coolant leak problem.
So.. if you ever have a bike that has the same problem as what i desribed then you know its either or a combination of failed rings/piston slap due to excessive clearance by putting a pattern piston in a standard bore.
| hmmmnz |
 hmmmnz Super Spammer
| darkangel |
| willi |
 willi Spanner Monkey
| willi |
| hmmmnz |
| lukamon |
 lukamon World Chat Champion
 Posted: 21:11 - 05 Oct 2007 Post subject: |
ANY play in the crank bearings means they are gone. the more you ride it, the louder it will become until eventually it sounds like a tractor. (this just happened to my kmx ) ____________________ killa wrote: Im an ass man myself |
| darkangel |
| willi |
 Posted: 01:36 - 06 Oct 2007 Post subject: |
sounds like piston slap to me. who measured the bore? did they take the measurement from the top of the cylinder or the bottom?? a cylinder will wear at the top more than the bottom like a cone. so have it checked again. 12000 miles is a lot for a two stroke of that size. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/
wat goes around comes around. |
| darkangel |
| darkangel |
| darkangel |
| willi |
| darkangel |
| darkangel |
The last post was made 18 years, 335 days ago. Instead of replying here, would creating a new thread be more useful? |
